GA-5AA rev1.1 Manual Available?
Reply 20 of 27, by ifrit05
OK, I may be reading the jumper settings wrong on the motherboard. Me being the competent computer person I am thought X=ON, and 0=OFF (0/1[X] meaning OFF/ON in binary right?)... The manual says otherwise.
I can get the MMX233 running at 233 with 66x3.5 2.8, but anything other than that is a no go or just downclocks to 200 or 133 for w/e reason that I can't wrap my head around. Why couldn't Gigabtye have used an easier to ready silk-screen???
Anyways... I may have accidentally ran the K6-2+ at 3.5V... It still gets a little warm so I know it's not just refusing to do anything but I don't have another way to test the CPU so it's either borked or just not compatible with rev1.1. I Just ordered a k6-2-550 (non-plus) so let's see if that gets me anywhere. At least it would be better than an MMX.
P3B-F v1.03 | VIA C3 Nehemiah 1GHz @ 1.33GHz| 4x128 PC133 | GeForce4 Ti 4200 | OPL3-SA3+DreamBlaster X2GS
Reply 22 of 27, by ifrit05
Well update, using the 1.1 manual, I created a custom google sheets... sheet using ON/OFF values to be less confusing to me. I finally got the MMX to post at 100x2.5, So on to the k6-2+. Will update soon.
If anyone is interested, here's my custom jumper settings sheet. https://docs.google.com/spreadsheets/d/e/2PAC … d=0&single=true
--EDIT--
Still a no go with the k6-2+ at 2.1v, I'm fairly certain even with the F7b BIOS this motherboard revision does not support the K6plus CPU's. Oh well, looking forward to at least a non-plus K6-2, and for the time being playing around with a P-MMX at 100x2.5.
Thanks for all the help guys, and if anyone else has any more ideas please chime in.
Reply 23 of 27, by CoffeeOne
@ifrito5:
According to
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
the board should fully support the K6 plus, even with the F6 bios.
If you have a possibilty try testing the cpu on another board. Or underclock it to 250MHz (2.5 * 100), but of course only with 2.1V not like the Pentium MMX 😁
But I am afraid, if you really have run it at 3.5V for some seconds, it will be dead now.
Reply 24 of 27, by Vic Vos
And here I was, getting a rev 1.1 with a K6-2+ 500... Ripperoni.
Reply 25 of 27, by ifrit05
Vic Vos wrote on 2020-01-10, 04:22:
Actually I got it to post with a K6-2+ 550. Now my problem is it will randomly reboot to a blank screen even while in BIOS. I thought it was heat related (did these old boards/CPU's even support high-temp shutdown/reboot?) but the heatsink is not even close to being warm when it happens. I have been pretty busy the past couple of days so I haven't been able to check if it's a voltage problem or my temp. GPU (GeForce 256 SDR, my V3 died unfortunately).
Reply 26 of 27, by gca
At high temp these boards just lock up. Found that out when my CPU fan failed and I didn't notice so it overheated. That was with a Cyrix CPU, maybe the AMD has a different reaction?
Reply 27 of 27, by ifrit05
Well I dug trough one of my boxes, turns out I have a GeForce2 GTS Pro (wow, thanks past me for saving all these old GPU's from my father's old PC home repair). I installed that and the issue disappeared. Now when it boot to Windows there's lines everywhere so I thing the GTS is on it's way out.
At least now I know it's not the motherboard.
