Reply 20 of 26, by dionb
- l33t++
kolderman wrote on 2020-01-09, 00:31:Does 430TX come with ATX? I had a look on feeBay they were all AT.
More than enough ATX out there - this was a 1997 chipset, around the time the transition to ATX got going.
Are they much better than the Ali and Via chipsets on most other SS7 boards? I have about 10 S7/SS7 and they are all Ali/VIA.
Depends very much o on how you define 'better'. Clock-for-clock Intel's memory controller (the same as in the i440EX, incidentally) is about 10% faster than Via's in the MVP3 and marginally faster than ALi's in the Aladdin V. Its PCI throughput is better and it is considered less quirky - not because it objectively is, but because Intel wrote the standard so its quirks became the norm.
Conversely it doesn't support AGP (which avoids AGP compatibility issues...), doesn't run at 100MHz (or above), which negates the clock-for-clock advantage, it only has one (1/2) PCI divider, so runs PCI out of spec on anything over 66MHz FSB, max L2 cache is 512kB and (much) worse, it can only cache 64MB RAM.
That makes the i430TX a good match with Intel So7 CPUs, with K6-3, where the internal L2 cache negates the lack of chipset caching ability and compensates the slower bus a lot. It is also fine for DOS and low-RAM Win95 stuff not needing the last drop of performance and not exceeding the 64MB limit.
It's a terrible choice for high-RAM K6-2 builds where you need the motherboard caching and high FSB for cache performance. It's also no good for touchy PCI cards that don't like speeds over 33MHz in combination with CPUs that run at bus speeds over 66MHz. And bottom line, if you want the highest So7 performance, you need either a high-cache MVP3 board or a very overclockable Aladdin V. No TX system will come anywhere near the performance of say a P5A running a K6-3+ at 4.5x133MHz.
