Hi.
H.W.Necromancer wrote on 2025-10-02, 15:38:
I am still following this story! The board is in good hands. Amazing job. I did such repairs too but this looks almost as good as before - like if nothing bad happened!! CUDOz!
Thanks!
Me & my 'chinascope' did our best 😉
You have ecouraged me to get back ti one SiS based Abit where I failed and burned our some pads. Same issue - loose pins all over the board. But due to the layout it is harder to fix it
Good luck - fingers crossed !
I decided to power up the motherboard to check if 85C501 doesn't explode 😉
85C501 seems to be  OK, CPU gets warm and the board is  absolutely dead silent.
 (Post card shows all voltages to be present but no post-codes on ISA/PCI).
I've checked all the pins around 'chipset' ICs and found out quite a lot loose legs in 85C503.
I think I'll resolder all of then in this chip.
Looks like the  DALLAS was 'hacked' quite brutally from the top without desoldering.
The attachment View recent photos.jpeg is no longer available
I've got a bunch of DALLAS chips, so I didn't bother desolering it, just cut off all the legs and removed them one by one.
There is some damage under it -broken trace and cracked SMD resistors.
The attachment IMG_2277.jpg is no longer available
