I went to your homepage the day of my post, and downloaded the first two links(dlls and patched .exe), I copied my dosbox folder, and placed everything inside. I get the CD-rom error at everything higher than ~2000 cycles
Load up is
game turns on-computer use light on my case blinks-(timer 2 error goes here and is now fixed)
CD-rom is accessed-CD-rom light blinks
Now loading screen appears on my monitor-CD-rom and main use light blinks as bar fills
After the rocket science now loading screen (where the previous poster was stuck, and I fixed by slowing dosbox), is a new screen that says:
Because this game plays interactive movies directly off the CD-ROM, it requires your processor, CD-ROM drive, and video card to work together in a very demanding way. Rocket science has analysed your computer and determined that the game may not play smoothly.
Here's how your system performed on our tests
Processor: VERY GOOD
CD-ROM drive: EXCELENT
Video card: BELOW OUR MNIMUM REQUIREMENT
Do you want to play anyway? (Y/N)
Pressing the n key gives the copywrite info and puts you back at the cd-rom prompt
Pressing the y key goes to a black screen (corrrection as of one minute ago: first time run of the game from turning my computer on gives a very choppy rocket science games logo movie then black, and if I exit dosbox, and load up again I get a black screnn only)
I will try messing with dosbox.conf some, some setting in it may help. That also means that my slow down dosbox fix may not be the solution, as I will need cpu cycles to run the game, but need to keep the CD-Rom slow.
The relevant game specs are:
Minimum 486-based IBM compatible with 4MB of RAM, running DOS 5.0 or later; MPC level 2 recommended
Double speed CD-ROM drive
VGA set to 256 colors; SVGA recommended
