H3nrik V! wrote on 2020-04-21, 18:18:
Oh, better hide that mains-power-outlet-measurement thingie .. It will only make you sad 🤣 and don't forget - energy spent in retro hardware is energy saved in heating .. 😉
Thank the heavens for sunshine and solar panels 😀
The serverworks chipset does not play nicely with Win98SE... 3DMark00 and 01 crash.
I'll test under WinXP and if that works, I'll redo all tests under WinXP. We'll use 512 MB of ram, to properly compare all chipsets under that OS.
@ OP, I don't want to hijack the thread, I'd just like to add some data to give the poor Tualatin some credit in its fight with the mighty Athlon 😀.
edit: The P3TDE6 will have its winXP on a SCSI 36GB disc, as the IDE is throwing fits as well.
edit2: AAARGH, 3Dmark99, 00 and 01SE all crash or halt on this system. I know the AGP on Serverworks chipsets is far from flawless, but what is the real issue here?
