1997 Pentium MMX Rebuild
Reply 20 of 93, by chrismeyer6
Excellent news!! I'm glad all it took was just cleaning the contacts to restore it's functionality.
Reply 21 of 93, by Intel486dx33
You might just want to use a CF card as a hard drive and use one of these.
https://youtu.be/hXk1AjRT2Pk
Reply 22 of 93, by Nick4
chrismeyer6 wrote on 2020-06-11, 15:14:
Yep, I very glad too!
Intel486dx33 wrote on 2020-06-11, 17:26:
Yeah, I saw that video=)
Maybe I`ll get this one. But It looks a little bit modern for my build.
Reply 23 of 93, by Caluser2000
You might just want to use a CF card as a hard drive....
By all accounts the OP is. And it's mentioned in his very first post.
Reply 25 of 93, by Caluser2000
Nick4 wrote on 2020-06-12, 08:14:
Caluser2000 wrote on 2020-06-12, 07:09:
I think he means to put it not in rack, but inside the case. And to install NewQ instead of rack.
Possibly. He quite often makes unclear posts here.
Reply 26 of 93, by Nick4
I have a chance to by a new in box Fujitsu SCENICVIEW A17-2 lcd monitor. I know it is not period correct, but it fits aesthetically and I can`t buy a crt monitor right now.
https://www.cnet.com/products/fujitsu-scenicv … lcd-monitor-17/
What do you think about this model, guys?
Also, I have an option a new in box Fujitsu-Siemens 19" A19-3. It is even cheaper, but 19" is too big, in my opinion.
orig
Reply 27 of 93, by chrismeyer6
It seems like it's a decent monitor. If the price is good I'd get it
Reply 29 of 93, by chrismeyer6
That's not bad for a new monitor
Reply 30 of 93, by chinny22
5:4 monitors are becoming uncommon, not rare but second hand market has more wide screen then not these days.
I've got a few Dell 1704 FPT's from work free, Nothing fancy, They aren't quick and not true 4:3 ratio but I don't notice.
already had 1 die on me (they have had 10+ years office use after all) so NOS would give peace of mind.
Reply 31 of 93, by Nick4
chinny22 wrote on 2020-06-16, 10:00:
I think I`ll keep looking for something more interesting. Theese monitors was low-end in 2005, so it`s not such a good choice, except it is new.
I have NEC 1770NX now, it gets the job done for now.
Reply 32 of 93, by Nick4
I`ve had some fun with led display jumpers and now i have correct "200" frequency. Too bad my motherboard does not support turbo button.
Curent setup looks like this:
MS-DOS 6.22 and Win 98 installed, but I`ve got some more CF cards to have more operating systems, so I can swap them when I want.
Reply 33 of 93, by chrismeyer6
That is a great looking system. Great job
Reply 34 of 93, by ATauenis
Some Socket 7 boards allowing using FSB or multiplier jumpers' pins as Turbo button pins. So the button can be connected instead of those jumpers and it will work.
2×8080, 2×Soviet ZX-Speccy, 1×MacIIsi, 1×086, 1×286, 3×386DX, 1×386SX, 2×486, 1×P54C, 8×P55C, 7×Slot1, 5×S370, 1×SlotA, 2×S462, ∞×Modern.
Reply 35 of 93, by Intel486dx33
Nick4 wrote on 2020-06-21, 14:35:
I`ve had some fun with led display jumpers and now i have correct "200" frequency. Too bad my motherboard does not support turbo […]
You can use the “Setmul” ( Set multiplier ) utility to downclock your CPU to a 386 or 486.
https://www.philscomputerlab.com/k6-2-2-3-resources.html
To use 386 speed in bios disable CPU and Motheboard cache.
To use 486 speed in bios disable motherboard cache only.
Use “topbench” Utility to check your CPU speed.
https://www.philscomputerlab.com/dos-benchmark-pack.html
Reply 36 of 93, by Nick4
ATauenis wrote on 2020-06-22, 09:56:
Here is my MB layout:
I don`t see how to connect it...
Intel486dx33 wrote on 2020-06-22, 10:13:
I know about that. I don`t need to slow down it now, just wanted to get all working=)
Reply 37 of 93, by maxtherabbit
how do people have room for desktop cases but don't have room for CRTs? it literally sits on top occupying no additional space
Reply 38 of 93, by Nick4
maxtherabbit wrote on 2020-06-26, 20:45:
I don`t have permanent place for it, so moving it around. It will be difficult to move it with huge 20 kg CRT=)
As I sad, I`ll get a CRT as soon, as I get permanent place for this desktop.
Reply 39 of 93, by chinny22
Depth, flat screen you can push further back and naturally bigger the screen closer to your nose a CRT becomes.
