Reply 20 of 20, by vvbee
vvbee
Offline
May well be the power supply that goes bad in those old machines. If the capacitors were selected with too tight voltage margins then a degraded supply turned on decades later could push them out of spec.
I had a look at the Intel 740, where it looks like their own manufactured boards used 25 V tantalums for 22 uF, Diamond used 20 V for the same, and some more obscure brand had 16 V. Right now 25 V tantalums can be about twice the price of 16 V, so you would've needed a good reason or deal to use them. Could be availability, but smaller manufacturers seem to have been able to ship boards with lower-rated parts.
