Reply 20 of 28, by feipoa
I decided to try out these two sets of 1 GB PC133 SDRAM:
The attachment Dell_610_2GB_DIMMs.jpg is no longer available
I first tried a single stick of the shielded RAM in the first DIMM slot. It worked. HWiNFO and the BIOS detected the RAM. However, I received an error code at POST,
Alert! One or more of the Memory DIMMs are out of rev.
According to the service manual, this means:
System detected that one or more of the DIMMs are not the correct revision.
With the probable cause being:
DIMMs do not meet Intel’s SPD 1.2 specification or 66-MHz DIMMs are installed.
The error is non-fatal and didn't appear to affect operation. I then put the second shielded DIMM into the 2nd slot, but I received beep codes. I tried the 3rd slot, but I received beep codes. I then tried the 4th slot and to my amazement, no beep codes. The system POSTed! But I didn't like that error. According to HWiNFO, these shielded DIMMs have SPD revision 0.2. I'm not sure why they have this revision. These DIMMs have a a mid-2000's datecode.
I next tried the non-shielded DIMMs and they too would only work in 1st and 4th DIMM slot when both modules were installed. However, the error message about the module revision being the incorrect revision was now gone!
The attachment Dell_610_2GB_DIMM_positions.jpg is no longer available
The attachment Dell_610_2GB_BIOS.jpg is no longer available
The attachment Dell_610_2GB_HWiNFO.jpg is no longer available
The attachment Dell_610_2GB_SPD_timings.jpg is no longer available
It still would have been nice to use the officially supported module size, but this is certainly the next best thing. I should point out that the start-up Dell progress bar takes a very long time with 2 GB installed.
Thanks to PC Hoarder Patrol for the comment to try unsupported 1 GB modules. Do your boards "Intel L440GX+ and a Supermicro P6DGU" officially support 1 GB sticks?
Reply 21 of 28, by PC Hoarder Patrol
feipoa wrote on 2020-09-01, 10:12:
In terms of official support the L440GX+ does, both for PC133 & 1GB
https://web.archive.org/web/20060427150131/ht … b/cs-014622.htm
although I can't find a version of the Tested Memory List new enough to list them
ftp://ftp.spez.com.ua/driver/mb/intel/l440gx/lgx_mem.pdf
The only modules on the Supermicro recommended list (they don't appear to have a QVL) for the BX/GX chipsets are PC100 to a max of 512MB per DIMM
https://web.archive.org/web/20031213135008/ht … 100_440GXBX.htm
although they do mention PC133 support briefly in a knowledgebase response, as long any particular module is backwards compatible with official PC100 spec - nothing about 1GB DIMMs though.
Here's a pic of examples of the various PC133R 512MB / 1GB DIMM layouts I have available for use across all my server / workstation boards (the bottom left one is the only one with stacked chips)
The attachment PCHPs PC133R.JPG is no longer available
Reply 22 of 28, by feipoa
That 1 GB buffered stick of PC133 CL2 must have been hard to find. Although it is easy to find such modules with IC's that support this speed, it is not easy to find one with SPD info for PC133 CL2.
Reply 23 of 28, by PC Hoarder Patrol
At the time I bought them (about 18 months ago) I didn't even notice they were CL2, they were just the cheapest delivered I could find reasonably local
https://www.ebay.co.uk/itm/Memory-Module-SDRA … wEAAOSwm3ZZrXvM
EDIT: and strangely enough I just noticed that they're also stacked! Think I'll test each set with HWINFO now to be sure.
Reply 24 of 28, by luckybob
I'm willing to bet, its turning off those 2 simms to allow the larger size to work.
If you put a small dimm in 2 or 3 do they work?
Reply 25 of 28, by feipoa
luckybob wrote on 2020-09-01, 23:02:
I'm not gutsy enough to try it. It is already at 2 GB. Trying 2 GB + 128 MB is more nerve than I have available.
Reply 26 of 28, by luckybob
Not even for science?
How about the for the thrill of it?
Reply 27 of 28, by feipoa
haha, I'm not such a risk taker. I suspect the system won't turn on, or at best, beep. There are some other anomalies with this slot 2 board that I'd like to start another thread to discuss. I think the thrill can move over there once I get my observations tallied.
Reply 28 of 28, by PC Hoarder Patrol
Found the later 2002 QVL for the L440GX+ which included the PC100 / PC133 1GB list
The attachment L44GX 1GB QVL.jpg is no longer available
