Voodoo 3 3000 AGP under performing?
Reply 20 of 80, by RockstarRunner
Right, I'm going to get to the bottom of this *raises fist to the sky*
I don't have a 128MB stick, but I just ordered one, and should get that in a few days, then I'm going to strip the system down, to just what you suggested... and see what happens.
Would it help at all, while waiting for that ram, if I posted my bios settings, in case anything stands out to you?
Reply 21 of 80, by cyclone3d
Try adjusting the CAS latency... The lower the better.
Is there a setting for DRAM Timing that is faster than Fast?
Can you disable DRAM integrity mode?
Note.. the first two can lead to instability songs ready to reset the BIOS if it fails to POST.
Only change one at a time.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 25 of 80, by RockstarRunner
I ran the memory benchmarks in aida32
The attachments are at 600mhz, but when I set the multiplier to 5.5 the write speed actually went up to 115MBS. Due to this, I ran 3dmark99 at 550mhz, and got 2400/7369, a bit lower than previously, so I'm not sure why that write speed was higher when I slowed I the cpu.
Reply 26 of 80, by bloodem
RockstarRunner wrote on 2020-09-30, 10:20:
Could this be related?
K6-2+/III+ slowdown issues on ALi Aladdin V
Unfortunately I don't see if they ever resolved that...
Don't think that would explain the very slow performance in Quake 2 (software mode). Also, you already have "VGA frame buffer" enabled.
Very strange issue, indeed... (but a lot of fun 😀 )
There's nothing that stands out to me as an indication of a potential issue. Your BIOS screens look good, and the Aida memory tests are also OK (even though the write speed is a bit on the low side).
Now you got me curious, I really want to test and debug a board with the Ali chipset (the last time I used a SS7 board with Ali Aladdin V was... 20 years ago).
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 28 of 80, by RockstarRunner
I guess the only next step I have is to wait for the ram (doubt it will help, wouldn't explain the big performance drop) then strip it down to the basics and build up, testing as I go. And after that, if it still doesn't change then I've no idea....
Would be interested to try with a non + CPU, but I'm not spending any more money on this.
Reply 30 of 80, by bloodem
Garrett W wrote on 2020-09-30, 19:45:
Try setting GAT mode to 0 in the ALi AGP Tool and see if you get any difference
This would not explain the slow performance in software mode.
Reply 31 of 80, by RockstarRunner
Decided to run memtest86... Why does it say I don't have any L3 cache?! Shouldn't that be the motherboard cache? Could it be bad/dead and thus explain the slowdown?
Please, anyone with a k6-2+... If you could share your results from memtest86 that would really help.
(I'm using memtest86+ 5.01 floppy version)
Reply 32 of 80, by bloodem
I don't think that would explain such a performance hit with a K6-2+ CPU. Typically, when the motherboard cache is disabled, the performance hit with a K6-2/3+ should be less than 10%, usually about 5%.
Anyway, I can check one of my SuperSocket 7 boards in the next days (because I'm currently doing tests with other platforms), and will get back to you.
Reply 33 of 80, by RockstarRunner
But, what if the L3 was bad, and I'm using a 256MB ram stick? Still waiting on the 128MB stick to arrive. I tested with the external cache on and off on bios, difference was negligible.
Reply 34 of 80, by bloodem
It should be the same. When talking about a K6-2/3+ CPU, I don't expect performance to drop by more than 10%, even if the cacheable RAM size is exceeded and / or motherboard cache is disabled.
Reply 35 of 80, by RockstarRunner
I guess the L3 cache is ok, according to this test...
I got the 128mb stick today, so I'll retest it all now
    1.32 MiB
Reply 36 of 80, by RockstarRunner
Is there any reason that the info screen in 3dmark 99 would show the bus as PCI?
    559.57 KiB
Reply 38 of 80, by cyclone3d
RockstarRunner wrote on 2020-10-07, 15:04:
With 128MB stick, I saw minor improvements, but definitely still something wrong. I've tried many things, but nothing really helps. I'm about to give up.
See here:
http://www.k6plus.com/phpBB3/viewtopic.php?t=1118
Looks like this board had issues with the K6-2+ even back in the day.
Maybe try the F7B BIOS as well. It is available directly from Gigabyte.
YMF7x4 Guide
Reply 39 of 80, by mbliss11
I vaguely remember seeing a video from Phil's computer lab where he ran into the issue of an AGP card showing up as PCI and that limited performance for him as well. I am not sure if it was driver related or chipset
