DOSBox vs forks and patches
Reply 20 of 35, by krcroft
jmarsh,
- the DOSBox-X team has integrated and tested your DMA status register fix: https://github.com/joncampbell123/dosbox-x/issues/1961, and I suspect it will appear in their next release.
- it's been further integrated into DOSBox Staging, https://github.com/dosbox-staging/dosbox-staging/pull/685 with yourself credited as the original author in the commit.
After seeing the documentation that Jon Cambell references, it's indeed a correction and improvement. Thank you.
Reply 21 of 35, by xcomcmdr
So I guess this emulation improvment isn't in DOSBox SVN ?
Reply 23 of 35, by xcomcmdr
Oh, good.
What about Nuked OPL ?
Reply 24 of 35, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Nuked OPL is another implementation of the OPL implementation that some people think is superior to other implementations. What else do you need to know about it?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 25 of 35, by Wengier
Many thanks to jmarsh, Jon Cambell and krcroft for the joint improvement efforts to the GUS implementation.
Reply 26 of 35, by xcomcmdr
Dominus wrote on 2020-10-25, 21:24:
All other forks added it as an option, and to me and others it is clearly superior. I compared to real hardware, and it's noticeably more faithful. Why isn't it in SVN ?
Any reason would be fine, but I did not find anything.
Reply 27 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
It's on the table to be checked to be added.
Do you have any games in which this opl core is superior to the others ? (so I can compare it myself)
Water flows down the stream
Reply 28 of 35, by xcomcmdr
Lands of Lore comes to mind, especially the forest part (beginning of the game) compared to a real SB16.
Edit:
Also, Cryo's Dune with Adlib music is clearly better with Nuked OPL enabled.
After all, this games contains specific drivers and uses undocumented features, or so the story goes anyway.
Reply 29 of 35, by jal
xcomcmdr wrote on 2020-10-26, 07:48:
Unless it uses the "composite sine wave mode", which afaik nobody has ever documented (not even Yamaha themselves), I don't think there are "undocumented features" in the OPL2.
JAL
Reply 31 of 35, by jal
xcomcmdr wrote on 2020-10-26, 09:05:
Ad Lib Inc., in its Programmer's Manual, shows the full register map of the OPL2, as far as I can see. So this may perhaps be a misinterpretation or a misremembering of that person.
But that's beside the point, anyway.
Agreed that it's besides the point. Dosbox should not strive to be "good enough" to play games, it should run the games as good as possible. If that means better OPL2 emulation, then I'd go for it.
JAL
Reply 32 of 35, by OldPlayer
jmarsh wrote on 2020-10-09, 09:30:
7 commits affecting the debugger in the past 12 months, including 2 in the past 30 days.
104 commits overall in the past 12 months.
Maybe take a look at the project's activity before declaring it dead?
We are now down to a single commit in the past 12 months. It’s dead, Jim.
With Staging and X we can see PRs being merged almost daily, they are attracting new developers, and if I was asked for a list of games which work better on the forks, I wouldn’t know where to start.
How about blessing one of the forks as an official DOSBox?
Reply 33 of 35, by jmarsh
Yes, because it turns out every time a commit was made to SVN it got adopted by some of these forks and trumpeted as if it was some grand improvement that they had implemented themselves. So now they're left to their own devices... good luck running DOSBox on anything but the latest and greatest hardware/OS without a bunch of unwanted dependencies along for the ride.
Reply 34 of 35, by Dominus
DOSBox Moderator
OldPlayer wrote on 2023-09-06, 19:31:
We are now down to a single commit in the past 12 months. It’s dead, Jim. […]
What is it these days? Too much sun and everyone needs to nag on DOSBox again?
And there is nothing to bless. X has forked so far away, pure might be an option but I wouldn't be able to judge, I'm not following it, and staging just burnt every bridge they could.
(IMO I my favorite of those is X as that is actually working on bettering the emulation)
Reply 35 of 35, by DosFreak
OldPlayer,
For questions on the future of DOSBox I suggest asking Qbix or Harekiet who are the devs responsible for it. Digging up old threads is not the way.
Keep in mind that the purpose of DOSBox is an entirely open source emulator to make as many DOS games work as possible on multiple operating systems and hardware without a lot of dependencies and with default emulated options and hardware to run as many games as possible without having the user having to configure hundreds of options.
It seems that people nowadays prefer the Apple method of throwing hardware and software away since there is no money in "old" things (even though those "consumers" bought it for alot of money....). So any replacement or continuation would need to decide if they are only going to use the latest and greatest programming language, compiler, OS, Hardware, etc and stop supporting anything older or support both or decide if there is a certain cutoff period based off of bad statistics or statistics they want to believe, facts please.
It also needs to make sure it's protected legally as far as so called "abandonware" is concerned so any such project should separate itself from that unless they have the funding, time and mentality to deal with it.
Something else to keep in mind is project drift or bloat. Just because a fork has a commit doesn't mean the original project should have that commit. Forks have different purposes, commits should stay with the fork if they don't align with the other project.
Make your games work offline
