Reply 20 of 27, by RayeR
- Oldbie
I boosted the Vcore at 3,66V (by adding 220k resistor at JP46) and was able to run at 160MHz . I don't know why but I have to increase L2 cache WS from 0 to 1 to be able to boot otherwise it always hangs at "Starting MS-DOS..." message (slow down of ISA and IDE related options doesn't help). On my DataExpert EXP4044 the L2 cache works fine with 0WS, the same 15ns Winbond chips...
Despite this handicap I broke through 50FPS in Doom and near to 16FPS in Quake:
MB CPU fCPU fFSB Speedsys CPU/MemBW VESATEST Doom* Quake 320/640**
Hippo 10 (WT) AMD Am5x86-P75 160 MHz 40 MHz CPU: 51,58 / 107,80 MB/s 15 MB/s 47,16 FPS 14,8 / 6,1 FPS
Hippo 10 (WB, L2-) AMD Am5x86-P75 160 MHz 40 MHz CPU: 59,72 / 118,16 MB/s 16 MB/s 50,38 FPS 15,4 / 6,6 FPS
Hippo 10 (WB) AMD Am5x86-P75 160 MHz 40 MHz CPU: 59,71 / 107,80 MB/s 15 MB/s 53,82 FPS 15,8 / 6,7 FPS
BTW it can be seen L1 has much more impact on the performance than L2. So I guess when I upgrade to 512kB (if that chinese crap from Ali will work) it wouldn't help much (just help to cache bigger RAM)
