Socket 5 pentium on socket 7 motherboard.
Reply 21 of 61, by cyclone3d
Baoran wrote on 2020-10-25, 17:59:
devius wrote on 2020-10-25, 10:18:
Just to clarify, if it has an AGP slot then it’s a “super socket 7” motherboard, not “socket 7”. I think there is a small misunderstanding here between these two terms.
I always thought term super socket 7 was just used to differentiate it when a socket 7 motherboard could do 100Mhz bus speed and if I was going to use it with older pentium cpu that doesn't need higher bus speeds it could be considered same as just socket 7 motherboard. The motherboards were called by the actual socket that you put the cpu in and this one has just standard socket 7 socket. The importance to differentiate would come if I were to build a system that needs the 100Mhz fsb to tell others that I have a motherboard that supports those cpus. Same as if someone had called socket 370 motherboards that support tualatin cpus "super socket 370 motherboards."
Correct. And there are SS7 boards without AGP.. such as those with the ALI Aladdin 7 chipset.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 22 of 61, by Baoran
One question remains unanswered. What is the max IDE hard drive size for this motherboard? It has award bios 4.51PG from 2000, so it seems that the bios has been updated at some point in the past. Any idea if the limit is 32GB or would it perhaps accept hard drives up to 127GB?
Reply 23 of 61, by dionb
cyclone3d wrote on 2020-10-25, 19:06:
"Super" Socket 7 was a marketing term, not a technical one, so it meant whatever the marketeer in question wanted it to mean.
Originally it was touted as the 100MHz+AGP+SDRAM combination, then boards with MVP3 chipset that could run async with EDO while doing CPU at 100MHz (whyyyyy?) also were 'super', followed by boards that had SiS 5591 chipset that maxed out at 95MHz, also 'super', then integrated VGA on internal AGP port also qualified as 'super'...
Bottom line: technically all these boards are So7 boards, with a superset of whatever features one wants to call 'super'. If I'd had to define it myself, I'd stick to the socket, as bus speed, voltage or I/O options never previously - or subsequently -defined a socket platform. Only thing the SS7 did on the socket that was different was enabling BF2 for twice the multiplier options.
Reply 24 of 61, by Baoran
I do have a K6-III+ cpu somewhere and that made me wonder. Does anyone know how would K6-III+ cpu running at 133Mhz compare to a 133Mhz penium 1 cpu when it comes to performance?
Like it does not matter what kind of cpu is inside as long as performance is similar. I can still pretend it being a pentium PC.
Reply 25 of 61, by kolderman
Baoran wrote on 2020-10-26, 03:21:
The k6 should be similar to a pentium pro at same clock IIRC. It should be faster than a plain pentium, but it would depend on workload.
Reply 26 of 61, by Baoran
kolderman wrote on 2020-10-26, 04:22:
Could you estimate how much faster average? Like would K6-III+ at 133Mhz be same as 166Mhz pentium? Would disabling motherboard cache make it equal to 133Mhz pentium for example?
Reply 27 of 61, by kolderman
Baoran wrote on 2020-10-26, 04:40:
For optimized workloads that took advantage of deeper pipelineals and extensions like mmx it could be much faster. But it really depends, the only way to know for sure would be to test the specific game in question.
Reply 28 of 61, by Dmetsys
dionb wrote on 2020-10-26, 01:12:
It wasn't a marketing term per se, and that's what Intel would want to make you believe.
AMD didn't have a new socket design at the time to compete with Intel's new Pentium II, and Intel didn't make 100 MHz BUS for Socket 7. AMD gained legal rights to Socket 7 after the Pentium II launch, and dubbed the socket 'Super Socket 7' for their K6-2+/3/3+ products. That designation is the proper technical term for any motherboard that supports those processors. People just tend to sway others away from it after the damage that was done by VIA. ALi based chipsets were actually quite stable for the time.
NF7-S 2.0 | 2500+ @ 3200+ | 9700 Pro | Audigy2 ZS
CUV4X 1.03 | PIII-933 | MX400 | Live! Value 4670
P5A-B | K6-2 450 | TNT2 | AWE64 Value
4DPS | Am5x86-P75 | S3 Vision864 | SB16 CT2290
Reply 29 of 61, by Baoran
Dmetsys wrote on 2020-10-26, 04:56:
It is probably unlikely the games I am planning to play to take advantage of mmx features since I am looking at late dos games and early 3dfx games in win9x because I am planning to use a voodoo 1 card with it.
Reply 30 of 61, by Doornkaat
I believe AMD had legal rights to Socket 7 long before Intel launched the Pentium II. Otherwise as far as I understand they would not have been allowed to sell processors using the bus protocol.
AMD then created a 100MHz bus specification for their upcoming K6-2 100MHz FSB processors in 1998, dubbing the platform "Super7" and registering for a trademark. (source)
In their technical documentation neither ALi nor VIA nor SIS referred to their 100MHz FSB S7 chipsets as "Super Socket 7" afaik. VIA describes their VT82C598AT north bridge as "Single-Chip Socket-7 / Super-7 North Bridge". (source) SIS sometimes referred to their integrated AGP solution as "Super AGP VGA". (source) In their chipset documentation they all refer to the supported processors as "Socket 7" processors. (see the aforementioned documents & ALi M1541 documentation)
AMD keeps avoiding the term "Super Socket 7" with the launch of their K6-III processors, describing them as follows: "The AMD-K6-III processor is Super7 and Socket 7-compatible. The Super7 platform is an extension to the popular and robust Socket 7 platform. See “Super7™ Platform Initiative” for more information." (source) Accordingly in this Article Anand Lal Shimpi refers to the "Super7/K6-2 platform" in context of the upcoming AMD K6-III.
However some motherboard manufacturers, system integrators and vendors have adopted the term "Super Socket 7" in their marketing. For example Asus did so on their P5A retail box while the manual uses either "Super7" or "Socket 7" but never "Super Socket 7". As another example DFI/ITOX lists "Pentium MMX and Super Socket 7 processors" as supported in their marketing. (source) Media reports also sometimes used the term "Super Socket 7" in their publications. (i.e. CNN reporting on the Athlon)
This admittedly quickly gathered evidence leads me to believe that "Super Socket 7" was indeed a slang/marketing term and not a technical term.
Feel free to comment if you have any findings that would disagree with this quick and dirty evaluation. 😎👍
Edit: Added quote from K6-III documentation.
Reply 32 of 61, by Baoran
cyclone3d wrote on 2020-10-26, 17:43:
You won't get a K6-III+ or most other K6-2 or higher chips to run at 133 because the 2x multiplier is a 6x multiplier.
I was just testing that.
Are you sure about that? "Setmul 2.0" dropped speedsys cpu score from 457 to 152.
I think you are right when it comes to motherboard dip switches at least. 1.5x became 233Mhz and 2x became 400Mhz
Reply 34 of 61, by Baoran
Thanks for the link. There is lots of good information there.
Bios auto hdd detection seems to recognize 120GB hard drive and set the size correctly. Is it safe to use it? I was sure the limit would be 32GB based on things I read online.
Reply 35 of 61, by cyclone3d
Baoran wrote on 2020-10-26, 18:20:
I was just testing that. Are you sure about that? "Setmul 2.0" dropped speedsys cpu score from 457 to 152. I think you are right […]
Oh, yeah. I hadn't thought of using setmul.
YMF7x4 Guide
Reply 36 of 61, by Baoran
Might anyone have a suggestion of what main video card to use with voodoo 1 card in this kind of system? I can kind of understand that the image quality and compatibility are the main points needed and havin another 3d card as main video card might not bring much to system like this. Matrox would be probably be best image quality wise but unfortunately all my Matrox cards are agp and someone mentioned earlier in the thread that I should not use an agp card.
The amount of pci video cards is bit limited. I have these at least:
Lots of S3 pci cards. S3 vision, Trio64, Diamond Stealth 64 and Virge/GX.
ATI rage II+ card.
I also have a voodoo 3 pci and a voodoo 3 agp card but using one of them would be kind of redundant with main purpose comes from the compatibility with early 3dfx games that comes from having voodoo 1 card in the system.
I also have 2 nvidia cards. Diamond Viper V330 4MB card and a TNT2M64 pci card.
I am probably going to install win98se there because that would allow me to take advantage of 2 USB ports in the pack of the soyo motherboard for transferring files to the system.
Reply 37 of 61, by kolderman
Virge GX.
Reply 38 of 61, by Baoran
kolderman wrote on 2020-10-27, 03:51:
Virge GX.
I did read some reviews online about virge cards from the time and they all say that they are bad basically.
Reply 39 of 61, by kolderman
Baoran wrote on 2020-10-27, 04:58:
Virge GX.
Ignore them, they are the best all round cards, at least the dx/gx are. There is an issue with brightness but s3bright can fix that.
