Reply 20 of 25, by Riikcakirds
darry wrote on 2020-11-03, 16:08:Try adding this cfg file DOSGAME.CFG and try also this file CFG801c.zip […]
Riikcakirds wrote on 2020-11-03, 15:09:thanks for the upload. Running cfg801b.exe gives the same error message "Fm801/FM1000 does not exist" Interestingly, running Dos […]
darry wrote on 2020-11-03, 12:38:Extreme long shot, but does any of these two files seem to work ?
Interestingly, running Dos801b.exe now gives a different message "DOS 801 cfg file error" it use to say "no FM801/1000 device".
I tried deleting volume.cfg and it gives the same "DOS 801 cfg file error".
Content of my volume.cfg file is:
[Volcfg]
Masvol=0
Pcmvol=0c0c
Fmvol=0c0c
SurVOl=0Try adding this cfg file
DOSGAME.CFG
CFG801c.zip
No luck with cfg801c and dosgame.cfg, still gives the "Fm801/FM1000 does not exist" error message. What did you modify, was it the PCI ID check?
I tried the card in win98 and the https://gofile.io/d/xOLYYn drivers don't work, can't find the device.
The drivers cyclone posted https://oemdrivers.com/sound-sound-blaster-live-dell-oem install and then the card shows up in device manager as a sblive, but sound doesn't work. Also the volume sound icon is also missing in the bottom right corner of windows (where the time is).
Pc-sound-legacy posted it might be Crystal CS4280, so I tried the dos driver for that model (CWCDOS.EXE), downloaded from http://web.archive.org/web/20010423093015/htt … ?pg=2&OpSysID=1
Running cwcdos.exe in dos gives the error 'A SoundFusion(tm) chip was not found'. Not sure what it is checking, obviously this card has a fake PCI ID and the The CS4280 is Vendor ID=1013, Device ID=6003. I'll have a go at installing these in Win98 but my main aim is to get sound working in DOS.
