Pentium 3 600 Katmai Voodoo 2 SLI System
Reply 20 of 25, by pete8475
crvs wrote on 2020-11-16, 22:13:
Greetings from cousin of your case, I kept it 486 though.
Very nice!
Reply 21 of 25, by kolmio
Hey @pete8475, how did you solve power on/off issue? The power button on this case is a toggle and not push type. How did you connect it, and PSU?
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium III 900, slotket | 512MB PC100 | Radeon 9250 | SoundForte SF16-FMI-03 | 64GB MicroSD
Reply 22 of 25, by pete8475
kolmio wrote on 2025-12-04, 11:37:
Oh it was never a problem because it's easy to adapt those with an ATX to AT power supply adapter like this.
That's just an image I found online, it's not the exact one I used in this machine. The computer is currently in a closet buried under other various projects so I can't pull it out to get pics at the moment.
Reply 23 of 25, by pete8475
Also if you can't be bothered to buy one of those adapters you can just connect the 2 pin reset button to the 2 pin power button connector on the motherboard (provided it's an ATX compatible AT board).
Reply 24 of 25, by kolmio
pete8475 wrote on 2025-12-05, 01:15:
So I assume you didn't have automatic power off, and sleep mode, right?
Reply 25 of 25, by pete8475
kolmio wrote on 2025-12-05, 03:55:
Yep.
EDIT - although if you're using an ATX power supply and the reset button connected to the power header everything like that should work just fine. I just like the clunk of the at power switch.
