QEMU connected to DOSBox IPXNET
Reply 20 of 25, by siljo
kjliew
would your patch work on windows 95?
Can you try command & Conquer red alert 2?
Reply 21 of 25, by kjliew
siljo wrote on 2021-08-24, 09:56:
Never tested there. There is no reason not to use Win98 for QEMU VM. It is less trouble with fast virtualization platform and all Win9x games work on Win98. I have never heard of any games specifically have to have Win95.
According to Google, RA2 is still playable through CnCNet today. Are you sure you need IPX for such a game released in 2000? I supposed the game was new enough to support TCP/IP for LAN play anyway. IIRC, I tested the 1st C&C GDI/NoD and it worked.
Reply 22 of 25, by siljo
update:
Atomic bomberman runs smooth on qemu,but not on virtual box.
I cant get connected on need for speed 2 se on qemu. the normal version not 3dfx. can you check please? I do get connection on virtualbox but it stays on race menu.
Pcem is not working, crashed.
Reply 23 of 25, by kjliew
siljo wrote on 2021-08-27, 07:11:
Then just get the 3Dfx version. 😉 It is so much better, I would have cursed playing the game if I had played the non-3Dfx version.
Reply 24 of 25, by siljo
Sure if you can give me how to ID10T 😁 instructions how to install 3dfx to qemu
edit:
Using this tutorial https://github.com/kjliew/qemu-3dfx
i installed MSYS2 MinGW 64-bit an when i try to use rsync -r ../qemu-0/hw/3dfx ./hw/ i get is command not found?
edit2:
got it working,but i get an error using ../qemu-5.2.0/configure && make
failed to create symbolic link .Igot this error when i try to tar,so i used 7zip to untar qemu 5.2.0
ninja: build stopped: subcommand failed.
make: *** [Makefile:171: run-ninja] Error 1
Reply 25 of 25, by siljo
Another update.
Atomic bomberman is runing smooth only if i disable -accel whpx,kernel-irqchip=off,but the is so sloooow in full screen.
Any idea?
