Reply 20 of 23, by Grayshazzle
Grayshazzle wrote on 2020-11-26, 07:55:Jorpho wrote on 2020-11-26, 06:37:As noted above, it is a self-extracting archive. The easiest thing to do would be to just open it with 7zip and copy the files […]
Grayshazzle wrote on 2020-11-26, 06:21:Actually I just checked out the torrent file and there doesn't seem to be anything but just olddos.exe, just that one file? Thanks.
As noted above, it is a self-extracting archive. The easiest thing to do would be to just open it with 7zip and copy the files where they need to go. Or just copy olddos.exe to an empty directory on your DOS computer and run it, and it will unzip itself.
Grayshazzle wrote on 2020-11-26, 06:22:for the CuteMouse directories, do I only need the bin folder and not doc or source, those are not needed I am pretty sure
What else do you think you would do with them?
Delete 😒 maybe
Sorry I meant for CuteMouse 🤣.
