Reply 20 of 37, by zlucarson
- Newbie
So I'm testing the caps currently. When touching the black lead to the 5V power contact and the red lead to the positive contact on some of the caps:
A majority of them zero out.
Two in particular (C17 and C14 near the power supply connector) have resistance values which cannot be measured by my multimeter (my multimeter can only measure as low as kilo-ohms unfortunately)
However all the other ones I measured charge up to .845 kilo-ohms.
I don't know if I'm checking them correctly, but I believe C17 and C14 are the issue, especially considering they're quite close to the power connector.
