Dual socket 7 build
Reply 20 of 74, by Sphere478
GPT disks on windows XP SP3 (partially solved)
Has anyone ever installed windows 7 on a non acpi motherboard? If so how?
Re: ATI Rage 128 Pro Won't Post
got a fx 5500 in it now
build is starting to come together
Sphere's PCB projects.
Reply 21 of 74, by matze79
What bloat ?
Windows xp is more bloated then 2000 😝
Reply 22 of 74, by Sphere478
Updates.
Got it working as a network share.
Initial network speed tests are in
3megs/sec at 80% cpus usage with usb 3.0 gigabit nic
4.5 megs a second 70% cpus usage with 10/100 pci nic
These results are kinda weird. Obviously neither neither the network, the cpus or the pci/usb are saturated. I wonder what is slowing it down...
This is fast enough for my uses over the network though but is going to be quite the pain transferring files.
Thoughts on speeding it up?
I have a gigabit realtec nic but it doesn’t even show up in device manager when I install it in the computer. And sometimes conflicts with other cards preventing booting
I was wanting to buy a killer nic but can’t find one for sale..
It’s idling at around 3-4% cpus usage and 95mb of ram right now (of 512mb)
Reply 23 of 74, by Oetker
Sphere478 wrote on 2021-02-25, 07:53:
Updates. […]
Updates.
Strange, if I'm up to date on your system you're running XP (98 suffers from slow network transfers) and you've determined your disk to be fast enough (i.e. not running in some slow PIO mode).
I'm surprised the PCI and USB nics are so close, as USB should have way higher CPU utilization. What kind of a PCI NIC is it?
Maybe memory bandwidth is your issue, although the throughput seems too low for that.
I used to use a P1-200 running M0n0wall as a router and I think it could push 100mbit.
Reply 24 of 74, by Sphere478
Oetker wrote on 2021-02-25, 08:13:
Strange, if I'm up to date on your system you're running XP (98 suffers from slow network transfers) and you've determined your […]
Updates. […]
Updates.
it's some linksys 10/100 running a realtec chipset I think
what is odd is nothing appears to be maxed out and the speed is between 10 and 100 speeds odd...
trying linux now
Reply 25 of 74, by Oetker
Sphere478 wrote on 2021-02-25, 09:46:
it's some linksys 10/100 running a realtec chipset I think […]
Updates. […]
Updates.
trying linux now
Good idea to try another OS, a higher-quality NIC (Intel) could help as well but I wouldn't expect the difference to be that large.
Reply 26 of 74, by cyclone3d
3COM and Netgear were the nics to have for Windows 9x... For XP, Intel should be fine as older Realtek were sometimes kinda wonky.
Make sure you have a NIC that does hardware offloading.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 27 of 74, by Sphere478
cyclone3d wrote on 2021-02-25, 10:19:
Oetker wrote on 2021-02-25, 10:03:
trying linux now
I want to try to find a pci killer nic but can't seem to locate one
got ubuntu 10.04 installed. haven't been able to figure out how to share anything but it's slow as crap something has both cpus pegged at 100% compared to 3-4% of windows XP
Reply 28 of 74, by Warlord
killer nic could be interesting. Personal experience with it was the drivers use up cpu and memory cycles just idle. So not sure what benifit it would be.
Reply 29 of 74, by luckybob
if you want a "killer" nic. Look for the Intel PRO series.
Both the 10/100 and gigabit series cards have a lot of features that offload work onto the card, and not the CPU. Drivers are mature and even still updated from time to time. I looked at the pro 10/100 drivers recently and the DOS drivers were updated by intel in 2019.
I've literally thrown away any network card (pci) that wasn't intel or 3com.
Reply 30 of 74, by Sphere478
luckybob wrote on 2021-02-25, 16:41:
how's OS support? win 9x? XP?
Reply 31 of 74, by Doornkaat
I think he's talking about this card specifically: Killer NIC M1 Gaming Network Card / Wikipedia article
Not just 'killer' as in 'great'.
Reply 32 of 74, by luckybob
Sphere478 wrote on 2021-02-25, 17:33:
the intel cards are supported on any OS you can think of. I'm also fairly certain the 3com ones are equally as supported. I know for a fact win9X and newer supports the 3com right out of the box.
Reply 33 of 74, by Sphere478
luckybob wrote on 2021-02-25, 17:37:
Intel 8492MT 82546EB PCI 2-Ports Gigabit Ethernet Adapter Network Card NIC DD
what do you think of this one? the others I see are pci X (not express) which I could use but would rather have something that doesn't hang over
yeah, I am talking about the killer nic 🤣
Reply 34 of 74, by luckybob
i threw that into ebay, and that looks like a cheap chinese knockoff card. I wouldn't recommend using that.
https://www.ebay.com/itm/254621849752
if you don't want it to overhang, the pro/1000 GT is the card you want.
The killer nic is a crappy copy of the Intel chip with buggy drivers. I wouldn't use one if someone handed me $100 to do it.
Reply 35 of 74, by Doornkaat
luckybob wrote on 2021-02-25, 17:54:
I'm fairly certain you're more knowledgeable than me regarding hardware and I agree that the product isn't worth the hassle but I do not understand how the Killer NIC (K1 or M1) are copies of any Intel chip.
Could you explain?
Reply 36 of 74, by luckybob
https://techreport.com/review/29144/revisitin … eight-years-on/
There are a few games that seem to work a bit better, but nothing even remotely worth the extra cost over a standard adapter.
The problem is software support. It likely won't support pre XP operating systems. To be fair, I haven't looked into it myself.
To reiterate, i go with Intel & 3Com, as they are fast, cheap, and well supported. I want to plug things in, and have them work with minimal fvcking about. There are plenty of other products that work okay, Realtek comes to mind, but the fewer drivers I have to hunt down, the happier I am.
Reply 37 of 74, by Sphere478
i threw that into ebay, and that looks like a cheap chinese knockoff card. I wouldn't recommend using that. […]
The card you found isn’t the one I was looking at.
Okay I’ll searh for that.
I would post the link but a admin told me not to post ebay links there are a unusual number of strange rules here.
Reply 38 of 74, by luckybob
Yea that ebay rule is the result of a 5-6 year long forum thread going absolutely tits up. I think the mods let me get away with it because it's usually to answer an inquiry, and never a self promotion listing.
That or they like me, but I doubt that.
Reply 39 of 74, by Warlord
Be interested in looking at the spec sheets between a GT and a MT. I used a MT adapter. Not sure if GT is better or not. PWLA8492MT Thats not going to work for you though as its for 3.3v slots only. I think your board only supports 5v slots. So thats something to consider.
