Are there other S3 Trio64 V2 Drivers Available?
Reply 20 of 23, by thepirategamerboy12
auron wrote on 2021-02-26, 21:40:
one difference between 95 and 98 is how the swap file and vcache are managed; if you have a lot of RAM installed (even just >32mb, according to some), it's usually said to set 95 to manually limit the vcache size because it can grow quite large and take a lot of memory away from programs to use. you can install system monitor from the windows install cd (add programs -> components -> accessories, i think) to check what your "faulty" win95 installation is doing in terms of things like this, and also cpu load; just note that the cpu load measurements are broken under win98 ACPI installs.
Finally feel like tackling this issue again. I'll check the vcache in system.ini in a bit.
Reply 21 of 23, by thepirategamerboy12
http://www.putergeek.com/vcache/
I just followed this guide and no, it didn't fix it...
Looks like I'll try reinstalling Windows (without formatting) pretty soon.
Reply 22 of 23, by thepirategamerboy12
I just finished reinstalling Win95 and testing some games. The issue seems to have gone away! I played through the entirety of Virtua Cop (my first time ever beating it, actually) and a fair bit of Croc and Atlantis and never noticed any of that annoying jittering whatsoever. Guess I should make an image of the drive soon. I do wonder what caused that issue in the first place.
Reply 23 of 23, by Rawit
Good that you managed to fix it. I wonder what triggers it.
YouTube
