Socket 7 to SLOT 1 adapter?
Reply 20 of 37, by ODwilly
C0deHunter wrote on 2021-04-14, 18:55:
Hello all, Is there such a thing available? I would like to have the flexibility to swap my PIII-800MHz SLOT with *possibly* a S […]
Hello all,
Is there such a thing available? I would like to have the flexibility to swap my PIII-800MHz SLOT with *possibly* a Socket7 CPU, that allows me to play some CPU Sensitive DOS games.
I believe there is an adapter for Celeron Socket 370, but I don't want that:
I need a Socket7 adapter, as I have plenty of loose original Pentium and MMX Socket7 waiting to be utilized.
My system specs are in my signature file.
Thanks!
There is a super rare Socket 8 adapter for Slot 1. You can run all the way down to a 166mhz Pentium Pro.
Reply 21 of 37, by C0deHunter
I know! I searched high and low, it is very rare, even 20 years ago!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 22 of 37, by flupke11
I have a 256kb cache PPro at 150 stock speed, and I think the first PPro's released as engineering samples were only 133 Mhz. Anyway, the PII233 with its FSB and multiplier options will be a versatile cpu for your needs.
Reply 23 of 37, by C0deHunter
https://www.ebay.com/itm/HP-PII-233Mhz-512k-S … o1a8zY1&LH_FR=1
This must be a typo on their page, but why it says HP PII CPU?
Reply 24 of 37, by cyclone3d
C0deHunter wrote on 2021-04-16, 00:10:
Because there is a sticker with an HP part number on the CPU.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 25 of 37, by C0deHunter
Actually they are using the exact same picture on all of their products, so it’s very confusing:
https://www.ebay.com/itm/Intel-PII-233Mhz-512 … r-/332630922513
And
https://www.ebay.com/itm/InteL-PII-233Mhz-512 … r-/332630922568
Reply 27 of 37, by C0deHunter
They have these part numbers,
SL264
And
SL2HD
Whereas mine has 5064-2651
Do you know why?
Did I buy the wrong CPU?
Reply 28 of 37, by PARKE
C0deHunter wrote on 2021-04-16, 01:08:
They have these part numbers, SL264 And SL2HD Whereas mine has 5064-2651 Do you know why? Did I buy the wrong CPU? […]
SL264
And
SL2HD
Do you know why?
You are fine.
The 5-digit numbers starting with 'SL' are Intel spec numbers. They are printed on the side of the cartridge.
Reply 29 of 37, by Anonymous Coward
I could be remembering wrong, but isn't that PPro-->Slot 1 adapter designed for a specific motherboard?
Reply 30 of 37, by C0deHunter
PARKE wrote on 2021-04-16, 01:43:
You are fine. The 5-digit numbers starting with 'SL' are Intel spec numbers. They are printed on the side of the cartridge. naa […]
SL264
And
SL2HD
Do you know why?
You are fine.
Thanks, I’m still not too happy with the HP designation on their website, I hope it’s not pulled from an HP desktop or something like that.
They claim they are new old stocks.
Reply 31 of 37, by rmay635703
Anonymous Coward wrote on 2021-04-16, 01:46:
Seems like they could work with specific chipsets, later chipsets needed the microcode update removed from the bios to post.
Too bad it’s so hard to get a PPRO working with an AGP chipset
Reply 32 of 37, by mothergoose729
What advantage does the Pentium pro offer over the pentium II with an unlocked multiplier? Just lower clock speed floor?
Reply 33 of 37, by Sphere478
if you google for it there is a thread somewhere where a guy claimed that they got a k6 working on a socket 370 motherboard there is even a pic of a k6 installed on a slocket out there also. but I'm 99% sure that they are hoaxes. if you look at the pinouts they aren't similar.
apparently pentium in a 386 motherboard is a thing though.
Edit from the distant future: I can now say without any doubt that there is basically zero chance that someone got a k6 working in a 370 motherboard or vice versa. Not by plugging it into the socket anyway. I’ve been working with the pinouts of these sockets recently and you would only get smoke of you tried this. Some sort of fancy interposer with super complicated bus translation chips might be possible but. Short answer, no. It didn’t happen.
Sphere's PCB projects.
Reply 34 of 37, by flupke11
rmay635703 wrote on 2021-04-16, 02:36:
With an adapter, the Ppro should work on some, if not all i440LX mainboards, providing they can handle the right voltage.
Reply 35 of 37, by Anonymous Coward
That might work if you have a 386-->486 upgrade adapter like the Transcomputer, and a POD83. But, you'd probably have to do something about the extra ground and voltage lines that overhang the PGA168 socket. Didn't the guy on VCfed do this with the Inboard PC?
Reply 36 of 37, by H3nrik V!
zyga64 wrote on 2021-04-15, 10:41:
Probably yes, but I only tested it at this speed, and that's all. No serial use, because for playing with early DOS I prefer my […]
H3nrik V! wrote on 2021-04-15, 10:06:
zyga64 wrote on 2021-04-14, 19:19:
I have for example PII 400 SL2S7 which can be clocked 133Mhz (2x66 without L2) and 166Mhz(2.5x66MHz with L2) up to 5x100MHz stable.
That's nice, and being a Deschutes core, you must be able to almost run it on passive cooling at 133 MHz?
Probably yes, but I only tested it at this speed, and that's all. No serial use, because for playing with early DOS I prefer my 486DX33 machine.
In fact it has original BIG heatsink which I don't know how to remove 😀 It looks exactly like this one. link
I rather prefer smaller cooling solution from original Intel BOXed processor (those are quiet).
At its original frequency (400Mhz) passive heatink is definitely not sufficient. It's too hot in my opinion, so small fan is attached in addition.
Good thing is - the motherboard I use (rather uncommon Totem P2BX with Intel BX chipset) has jumper for 66/100MHz so FSB can be changed on the fly (tested by me)..
Wow, that's a cool (pun intended) looking heatsing 😉 But I agree, that at rated 400 MHz, active cooling will be required.
Reply 37 of 37, by Rawit
C0deHunter wrote on 2021-04-16, 01:59:
It just means that it's a (replacement) part for HP computers. HP and other brands give Intel parts an extra sticker/serial number so they can specify replacement parts/upgrade paths in their manuals and trying to tie you to the brand. It's a genuine Intel part so no worries.
And you chose well. I actually tried running the cacheless Celeron 266Mhz with speed sensitive games and it isn't slow enough. Some games on the Vogons Wiki seem to max out around the Pentium 233Mhz mark, but the Celeron is faster than that in those cases. Games like Jazz Jackrabbit still needed to be patched with the Celeron.
YouTube
