Reply 20 of 23, by Postman5
- Member
Blowing with an external fan will be the best solution.
A must read for all Velosity 100 owners 3dfx glide2x.dll 25-years old bug in the system [affected all v3 cards with 8MB vmem]
holaplaneta wrote on 2025-02-03, 23:00:jasa1063 wrote on 2021-04-20, 18:08:I have installed active cooling, overclocked to 166MHz and applied the 2nd TMU registry hack with no issues:)
Any tips, advice or tutorial on how to install active cooling on these cards? Thanks!
Here is a cooling solution from a seller on eBay you may want to look into.
jasa1063 wrote on 2025-02-11, 03:50:holaplaneta wrote on 2025-02-03, 23:00:jasa1063 wrote on 2021-04-20, 18:08:I have installed active cooling, overclocked to 166MHz and applied the 2nd TMU registry hack with no issues:)
Or take any 40mm fan and order a sticker from Geekenspiel... You'll save $20! Like I did...
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX2 66, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Thanks for the tips folks!
