Reply 20 of 25, by kingcake
megatron-uk wrote on 2021-05-04, 19:40:
Well done! That's a pretty mammoth job - I bet you were seeing solder points in your sleep afterwards! 😁
At some point I have to revisit a homebrew Z80 backplane that I foolishly soldered several of the connectors on 180 degrees out of alignment... each one is a 96-pin DIN 41612 connector. I did 3 of them the wrong way around before I realised my mistake....
Oof good luck fixing all those joints. Just reading that gives me soldering ptsd 🤣
Reply 21 of 25, by kingcake
Putting the system back together. Forgot about the riser card! It has leaking caps, too! Replaced them with some tantalums I had laying around.
707.91 KiB
Reply 23 of 25, by weedeewee
@kingcake, nice to see you also post it on facebook. At least I'm guessing it's you.
Do not ask Why !
Reply 24 of 25, by evasive
Is this board in UH19 yet? Before you put your whole system back together, we'd like a clear picture of the front and back of the board then.
http://www.win3x.org/uh19/
Reply 25 of 25, by Caluser2000
pentiumspeed wrote on 2021-04-21, 22:37:
Replace memory. If more than one (72 pin), take one out and rearrange. Or four (30 pin), you will have to change as a set.
Cheers,
You don't need to change the whole set of 30pin simms. Replacing one at a time will find the faulty stick.
