Digital Venturis 466 + AMD 486 DX2-66V16BGC
Reply 20 of 27, by butjer1010
CoffeeOne wrote on 2021-05-29, 17:15:
:D :D :D On the right side of the photo there is a 5volts Intel DX2/66 cpu. Why don't you use that one? […]
butjer1010 wrote on 2021-05-28, 20:50:
evasive wrote on 2021-05-28, 07:35:
http://www.win3x.org/uh19/motherboard/show/1819
we would like a photo of the motherboard 😀
Here is the picture with jumper settings for AMD DX2, but no POST with that setting. BIOS is 2.04.
EDIT: Ok, it might be an DX2/50 only, so for 25MHz bus. But with a good cooler, it will likely run fine on 66MHz
Yes, as i said in first message, Intel is working well, but i am biggest AMD fanboy ever, and i want to create "AMD collection" for myself. Intel is for testing purposes only 😀
Reply 21 of 27, by butjer1010
Anonymous Coward wrote on 2021-05-29, 10:32:
There are a bunch of cheap vrms on eBay right now.
Can You please send some links of VRMs, that will fit on this board?
Thanks in advance
Reply 22 of 27, by butjer1010
evasive wrote on 2021-05-29, 18:31:
Thank you for the picture, it is added to the page. […]
DOS utility used to extract BIOS images:
http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
If you have time and energy, a bios backup would be welcome too 😀
I downloaded latest BIOS from http://www4.support.compaq.com/support_databa … ndex/epid41.htm
PC Hoarder Patrol sent me this link, and it worked!
Reply 23 of 27, by butjer1010
nuno14272 wrote on 2021-05-29, 21:36:
I have the same board... With a AMD dx2-66. Jumper J3 is on by default...
Which model (NV8T, V8TGC, or older one DX2-66 and DXL2-66) ?
Thanks
Reply 24 of 27, by The Serpent Rider
You're trying to boot rebadged 486DX4 WB. Of course it won't work.
Reply 25 of 27, by CoffeeOne
butjer1010 wrote on 2021-05-30, 10:33:
Hello again,
Honestly spoken I did not read your first post carefully.
I thought you were replacing a 486DX-50, but you are going to replace a 486DX2-50 with a 486DX2-66.
so the 66V16BGC is not working, I also think that it does not run with 5V.
But the whole thread is now making even less sense to me. You are really trying to find now a voltage adapter to make an upgrade from 50 to 66MHz?
When your orginal CPU will work (most likely) on 66MHz, too (?)
Hmm.
Most of the additional features of the newer CPU (level 1 cache write back mode) will not work anyway, if you manage to make it working, it will be for sure L1 WT mode.
Reply 26 of 27, by butjer1010
CoffeeOne wrote on 2021-05-30, 15:28:
Hello again, Honestly spoken I did not read your first post carefully. I thought you were replacing a 486DX-50, but you are goin […]
Hello again,
Hmm.
No, i want to "upgrade" from Intel to AMD, not 66 from 50. 😀
Reply 27 of 27, by butjer1010
Thanks for the link, but the seller won't send it to Croatia, where i am from. But i will try to find it in Europe.
