Reply 20 of 26, by mkarcher
Joseph_Joestar wrote on 2021-06-16, 20:07:640K!enough wrote on 2021-06-16, 18:51:The original Microsoft WSS board used an Analog Devices part, which was still at 534H, but other functionality was exposed at the other four I/O addresses (530H-533H). Some controllers reproduce that whole set-up (I think OPTi/MediaChips controllers do), whereas the Crystal controllers are only WSS CODEC compatible.
That's some very Interesting info. Considering that an Analog Devices chip powered the original Windows Sound System card, it makes sense that other sound cards that have their chips on-board would have the best WSS compatibility.
And yes, OPTi did often use Analog Devices chips on their cards, which is likely why their WSS compatibility tends to be top notch.
AFAIK the Crystal chips works as good as the analog chips as WSS CODECs. Both of them behave the same, and are used to implement addresses 534-537 on WSS-like cards. The more important compatibility issue is, as 640K!enough already mentioned, the four ports below that, on 530-533. The original WSS cards used these ports to configure DMA and IRQ of the card. Some games try to detect DMA and IRQ settings by reading these ports. This fails on a lot of sound cards that use their own configuration mechanism instead of the WSS one, no matter whether they use an AD1848 or CS4231 as CODEC.
