Duke 3D with VDMS
Reply 20 of 32, by Nicht Sehr Gut
Originally posted by Dijeeh ... and thus VDM settings dont come into play when rr1.exe is run.
Thus, i get IRQ conflict error if sound is on
Dijeeh, did you ever find what was interfering with VDMSound? You were referring earlier to using Cli2Nop in XP.
I pointed out that shouldn't be necessary in XP and asked about GIVEIO.SYS. You said it wasn't there, but if you're still having these kinds of problems, then something is interfering with your OS.
Reply 21 of 32, by Snover
Dij, I dunno what to tell you about the forum. Nobody else has been having these problems, and it's just vBulletin.
Yes, it’s my fault.
Reply 22 of 32, by Dijeeh
Right now im no longer having problems with anything.
For the first time in its history this BB remembered my login.
I didn't change a thing now it works 😀
Well , games lockup on the first sound being played without me using CLI2NOP
When i use it, i have no issues at all, as far as im concerned, the problem is solved!
On a fresh format of XP Pro by the way, nothing has been installed that would take over sound or interfere
Reply 23 of 32, by Nicht Sehr Gut
Originally posted by Dijeeh When i use it, i have no issues at all, as far as im concerned, the problem is solved!
Well, that's good to hear, but I'm convinced that's temporary. Kind of like driving a new car that makes constant "THUMP-THUMP-THUMP" sound when you drive it. It may seem to run properly, but still..."it ain't right".
It's just the last time something like this came up, we got the same kind of responses and it did turn out to be a minor program that had been installed (but they were convinced it wasn't related).
Reply 24 of 32, by Unregistered
Lets see...
i got MSN
(sounds off and usualy not even running when im playing games)
Office XP
If i go into taskmanager, there is really very little running bar explorer, svchost ect ect
network stuff
That's it!
Reply 25 of 32, by Dijeeh
For F*ck sake, its forgetting my login again!
Why this board and ONLY this board?!?!?!?!!!!!
ARRRGGG!
the above post was me!
Reply 26 of 32, by Unregistered
Hey all
Managed to get the sound sorta working...
Gets about 2 seconds into the intro and then crashes out with that base ganular shit
Win2k
VDMSound 2.0.4, Update 1, CLI2NOP
Reply 28 of 32, by Stiletto
DosFreak wrote:
Sigh.
Ditto.
do the Fandango!" - Queen
Stiletto
Reply 29 of 32, by Nicht Sehr Gut
I think the thread has gotten off-track. As I understand it, "Unregistered" used the original Cli2Nop and it's not working well. My guess for the next step would be to re-install Duke3D (NOT Cli2Nop'ed). Then run Snover's modified CLi2Nop on it.
BTW, Dijeeh "Redneck Rampage" was covered pretty thoroughly in this thread:
showthread.php?threadid=474
If you still can't figure it out start a new thread and we'll see what we can do. Can't afford to mix different games/people in the same thread, it's a "Confusion Generator".
Reply 30 of 32, by Snover
The conflicting process doesn't always show up in TASKMON. Many times it's a service that is running. Check your services CPL and make sure you are viewing hidden services as well.
Yes, it’s my fault.
Reply 31 of 32, by Dijeeh
Nicht Sehr Gut wrote:
I think the thread has gotten off-track. As I understand it, "Unregistered" used the original Cli2Nop and it's not working well. […]
Don't worry , It works , There is no problem anymore, NOLFB solved the problem with DPMI error and VDM gives me sound.
Problem over !
The dij speakes wisdom once more.....
Reply 32 of 32, by Snover
Okay. Guess I'll close this thread now: RESOLVED. 😜
Yes, it’s my fault.
