Ultimate multi-sound card setup?
Reply 20 of 32, by AppleSauce
dionb wrote on 2021-09-12, 22:54:
aitotat wrote on 2021-09-10, 04:40:
It has been a long road to find this combination but it is the best I've come up for my DX4 system:
Then there is another limitation as well. Most early General Midi games are hardcoded to port 330 and that is used by the Roland MPU401AT + McCake combo. So I have to use McCake for General Midi for some games. That is not a big problem since McCake is excellent for that as well but If you want the Roland GM/GS sounds then it is a problem. I should be able to fix it with software (port trapping) and I could also plug external Roland module to MPU401AT but I want this system to have everything internally.
Maybe you could put your wavetable module into an external MIDI enclosure (Chill or similar), then get a MIDI switcher/patchbay to choose which MIDI device gets its stuff from the MPU-401. WIth a real MPU-401, an MPU-105 would be the obvious (if hard to find) choice.
Oh damn so is the 104 the wrong choice then? , I've seen LGR use it with his midi tower and it seemed okay.
I guess I got the input to output mixed up then , dang.
Reply 21 of 32, by cyclone3d
AppleSauce wrote on 2021-09-12, 23:37:
You really don't need a special "MIDI output selector". Any simple switch box that has DIN-5 on it will work fine.
For that matter, you could use any switch box if you were willing to make cable converters.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 22 of 32, by AppleSauce
cyclone3d wrote on 2021-09-13, 00:18:
Well that's good news then.
Reply 23 of 32, by Pierre32
It's a bit of a thread derail, but I just got curious about the MPU-104 and MPU-105. The 104 is an input switcher (so in this context, you might have 5 retro PCs connected to one SC-55). The 105 is an output switcher (so, one retro PC connected to multiple MIDI modules). You can see how the 105 would be the one you'd need here. Yet, in LGR's MIDI Mountain vid he is clearly using the 104 as an output switcher. Which suggests that they're both the same thing internally, just labelled and marketed differently.
https://www.mesonline.com/keyboards/roland_mpu104-used.html
https://www.mesonline.com/keyboards/roland_mpu105-used.html
As cyclone3d says, you don't need either of these. (I just use a Quadra Thru to send MIDI to everything at once). But if you have one, neat.
Reply 24 of 32, by mothergoose729
Idk about "ultimate" but my slot 1 board has...
Orpheus with Hard MPU - OPL3 sound blaster pro 2 support, WSS 2.0 support (mostly) external midi via MUNT and Roland Sound Canvas VA
Aureal Vortex 2 for A3D 2.0 stuff
Audigy 2 ZS for EAX and basically anything else windows
I have been tempted to add a sound blaster 64 value card for SB 16 compatibility which would make it basically perfect IMO, but I spent so much time setting up everything I am afraid to throw a wrench into it.
Reply 25 of 32, by AppleSauce
Pierre32 wrote on 2021-09-13, 01:43:
It's a bit of a thread derail, but I just got curious about the MPU-104 and MPU-105. The 104 is an input switcher (so in this co […]
Yeah gonna derail a bit as well(sorry) but interestingly , while my 104 is a plain bare circuit board with a diode and resistor and some traces
the 105 seems more involved
and according to the only picture I could find of it online opened up has some glue logic chips .
Not sure why though.
104 PCB
1008.07 KiB
105 PCB
178.33 KiB
Reply 26 of 32, by dionb
AppleSauce wrote on 2021-09-13, 06:17:
Yeah gonna derail a bit as well(sorry) but interestingly , while my 104 is a plain bare circuit board with a diode and resistor […]
104 PCB
105 PCB
Frustrating lack of better pics than that online. Those ICs on the 105 look like pretty basic, but could be lots of things (something from 74-series?).
On a side note, I have a Roland A-880 imported from Japan - and faced with a 110V PSU I instead modded it to work off USB (hooked up to 5V line coming out of VRM). Works like a charm. Probably also possible with these smaller, simpler units.
Reply 27 of 32, by AppleSauce
dionb wrote on 2021-09-13, 10:01:
104 PCB
105 PCB
Ah that sucks , I would have thought you could change the voltage like on a SC-88s transformer.
Good solution though.
As for the chips , they appear to be HD74LS03P chips?
Quadruple 2-input Positive AND Gates (with Open Collector Outputs)?
Reply 28 of 32, by BloodyCactus
I have a 104 + 105, they are not the same internally. the 104 is even passive, no power required, the 105 requires power.
i mothballed both of mine to use a Roland A-880 instead.
Reply 29 of 32, by dionb
AppleSauce wrote on 2021-09-13, 11:51:
Nope, internal transformer. As usual perfectly documented by Roland with spare part numbers given, but the "rest of world" coil needed is of course nowhere to be found. All looked pretty primitive/inefficient too - huge coil, then some diodes to do AC-DC followed by some caps to smooth out their output. Pretty sure my Ikea power socket with USB power is more efficient 😉
Tnx.
Reply 30 of 32, by vutt
System: PIII 933 Slot 1 Win98 + DOS 7.1 (with L1 cache on/off for 386 level speed sensitive games)
Main DOS: SB32 CT3670 for SB/SB16/AWE games (Adlib/Creative FM disabled)
Main Win98: Yamaha YMF744 PCI for Win98 with basic EAX/A3D support. In DOS only FM enabled for authentic Yamaha OPL3
External modules: Yamaha MU80 for GM and DIY MT32-PI unit for MT32
I have signed up in spring for Orpheus. Hoping to get it by Christmas 😀
I will then have challenge how to cover SB16 and A3D in the same time. I have SB16 (CT2770), SB32, AWE64, SBLive, Audigy 2CZ, Audican 32, ES1868F, YMF719E, Vortex2. I'd like keep 2 card setup. Probably not possible in order t cover everything.
Reply 31 of 32, by Joseph_Joestar
vutt wrote on 2021-09-19, 16:19:
Your YMF744 can handle A3D 1.0 through Sensaura.
It works quite well, especially in games based on the Unreal engine.
Reply 32 of 32, by gdjacobs
BloodyCactus wrote on 2021-09-13, 12:41:
The 105 is likely buffering each output so the current draw on the source device isn't out of spec.
