Reply 20 of 44, by roytam1
Azami wrote on 2026-02-13, 12:54:It should print help if you enter 'help'. I made a few cosmetic changes yesterday but nothing should change the help text behavi […]
I made a few cosmetic changes yesterday but nothing should change the help text behavior.Just tested on Windows 3.1/NT 3.51/10/wine with no issue.
alright just found the problem in my side. some object files are compiled with old defines, and recompiling them works now.
and plink in NT 3.1 works, but there is no ansicon for NT 3.1, and you need to wrap with k95 for better ANSI escape code decoding.
save this as "k95plink.bat" and run `k95plink remotehost` in cmd window will help, unless your remote-host doesn't emit any ANSI escape codes then you can use plink directly.
@k95 -C "set terminal color terminal-screen white black , set terminal statusline off , pipe plink %1 , exit"
