Reply 20 of 59, by Dege
Strange. I don't have an idea at the moment. This is what I get, and I can't see any difference compared to dgv1:
    203.09 KiB
Reply 21 of 59, by BEEN_Nath_58
Dege wrote on 2022-05-25, 17:46:
This is the correct visuals as seen with dgv1 on my end as well.
Maybe logs can help. Is there a debug build available?
Reply 22 of 59, by BEEN_Nath_58
I did quite a few test and the results are same on Windows 7 as well. On Win98 and Voodoo 1, this game doesn't run for some reason so I have only newer platforms to test.
Reply 23 of 59, by BEEN_Nath_58
The screenshots below depict how the game looks in different places:
dgVoodoo1 + dgVoodoo2
HUD Loading
file.php?mode=view&id=138165
HUD Loaded
file.php?mode=view&id=138166
Pause Menu
file.php?mode=view&id=138167
Reply 24 of 59, by BEEN_Nath_58
And here's how the game looks in the new Glide.dll with or without dgVoodoo2 DirectX:
HUD Loading
file.php?mode=view&id=138168
HUD Loaded
file.php?mode=view&id=138169
Pause Menu
file.php?mode=view&id=138170
Reply 25 of 59, by Dege
Ok, but I still don't have an idea why it is. What about different API's? Do you get the same with D3D11 WARP, D3D11/12?
Edit: the dbg version wouldn't help here because there's no much to report in Glide. Only activating/initialization/deactivation stuff.
Reply 26 of 59, by BEEN_Nath_58
Okay I got some hints, the game loads the HUD when Force Emulate True PCI Access is disabled, but it presents a flickering HUD:
Reply 27 of 59, by Dege
Yes, that's the expected behavior with disabled PCI access. That's why I don't understand why the enabled case does not work for you.
Could you plz try it with output API set to d3d11warp, just to rule out the possibility of any driver problem?
Also, if there is ddraw.dll in the game folder, delete it to avoid mixing it with Glide.
Reply 28 of 59, by BEEN_Nath_58
Dege wrote on 2022-05-28, 10:39:
Yes, I just deleted the ddraw.dll and d3dimm.dll files and tested with D3D11WARP and the results are the same, the below-left HUD stops loading midway as I explained. I also tested with an older Nvidia driver and the result is same as well.
Reply 30 of 59, by Dege
I'm still not having an idea. We're using the same game version, the same wrapper version, etc, so I don't yet understand what the difference is.
I'll check it out on other machines, maybe only my computer is 'special' in some aspect.
Reply 31 of 59, by BEEN_Nath_58
Dege wrote on 2022-06-05, 08:04:
Sure that'll be good 😃
Reply 32 of 59, by Dege
I tried it on other machines but it worked.
I have only one idea: emulating PCI access relies on catching certain exceptions. I don't know DxWnd immersively but doesn't it have an option to absorb exceptions?
I installed Mech2, along with a 'clean' DxWnd installation (2.05.83.fx4) and only imported the MechWarrior 2 31st Century Combat.dxw from the installation guide without changing any option afterwards.
Reply 33 of 59, by BEEN_Nath_58
Dege wrote on 2022-06-13, 14:37:
I tried the new package and it didn't change anything. Well I think I will just do a driver resinstallation now and see if anything better happens. I forgot to tell there's a game crash when using only dgVoodoo2 Glide, on exit but that doesn't happen with dgVoodoo1
Reply 34 of 59, by BEEN_Nath_58
BEEN_Nath_58 wrote on 2022-06-16, 17:14:
Okay so after a driver update, nothing changed. Well I think I have to pause here until a Windows reinstall, something must have gone wrong intensively to emulate such behaviour. Maybe the crash is also related to it.
Also you asked about the catching of exceptions. Yes, DxWnd does it, and is also enabled for the game, even for your configuration, to ignore the exceptions caused by the WINMM on Windows 8+ platforms. DxWnd, as far as I know, shouldn't be catching Glide exceptions as it handles DirectDraw/GDI/OpenGL mostly.
Reply 36 of 59, by ghotik2002
Oh, I see ....
About guard page exceptions (code 0x80000001) DxWnd does not do anything special. So, there are two cases:
a) with DxWnd handle exception turned off, it doesnt intercept the exception. Hopefully someone else should do it?
b) with DxWnd handle exception turned on, it treats the event as harmful, so it jumps over the offending assembly and continues the execution.
Probably, the second case could give some troubles because this way the guard page exception will be masked so preventing the allocation of a further block of memory for the stack.
Possible variations for DxWnd handling could be the following ones:
1) consider guard page exceptions as welcomed and let them pass to the exception layers above
2) maybe as in case 1) but only when some dedicated option is enabled
3) implement a guard page handling inside the VirtualAlloc wrapper, repeating the operation after the stack is increased?
4) anything else?
I'm open to suggestions.
Reply 37 of 59, by Dege
How to handle guard page exceptions when the game is needing them is a question... I don't know if it is a problem in practice, so that, is there any game that needs guard page exceptions catched and absorbed while they also neeeded for a third party stuff like dgVoodoo.
But, I still understand the basic case: GP excpetions uncatched and defective HUD in MW2 through dgVoodoo.
Maybe Gho, could you try this game yourself plz, to let us have a 3rd use case?
Reply 38 of 59, by ghotik2002
Ok, if I understand correctly the test case would be this one:
Mechwarrior 2
dgVoodoo2 DirectDraw wrappers
DxWnd with handle exception flag but (experimental custom feature) leaving the guard page exception 0x80000001 uncaught
The hope would be that dgVoodoo2 + some handle exception but not the guard page that must pass, all this would make MW2 playable.
It is a dream, but it's worth trying. I'll give BEEN_Nath_58 a custom DxWnd release.
