A-Trend ATC-1442G missing capacitors!!!
Reply 20 of 20, by butjer1010
majestyk wrote on 2022-06-11, 16:23:
The correct frequency of the oscillator is 14.318 MHz as snufkin pointed out. The datasheet is always right 😀
I think your current problem has some other cause. Did you try installing DOS or WIN with all 9 cache chips removed? Is the cache jumpering 100% correct?
Same goes for the CPU voltage jumpering.
You were right, there was problem with jumpers only. The incomplete manual that i found, showed me that the jumpers weren't good for this cpu. When i adjust them, everything works fine, i installed win95 with no problems! Thanks everyone, You all helped me a lot!
