Reply 20 of 24, by Robx66
Tried hotflash which was a success but motherboard still doesn't post 🙁
Save vintage / retro computers from ending up in the bin. Keep them in working condition. It's a great history !
Reply 21 of 24, by jakethompson1
Robx66 wrote on 2023-05-20, 15:24:
Post card finally arrived so plugged it in and that's what it shows..... It's in PCI slot, no codes, all leds on apart from 3.3 […]
It's in PCI slot, no codes, all leds on apart from 3.3 Volts, irdy, frame, reset. No beeps
In ISA as you can see.
Dead ???? or there is still something I can do or try ?
When using the ISA slot you have it plugged in backward
Reply 22 of 24, by Robx66
jakethompson1 wrote on 2023-05-24, 21:41:
Eeeeeeeeeee I thought it was the right way 🙄
So that rear thing means rear of the computer and not the rear of the isa slot which is the opposite side .....
Reply 23 of 24, by Robx66
Put the card backwards in isa slot and that's the result...
Reply 24 of 24, by rasz_pl
Robx66 wrote on 2023-05-11, 19:21:
Only one part get hotter to around 40-50 Celsius is Winbond W83768F but this is the I/O controller
its not, its a buffer for serial ports, if it gets hot it might be blown, wouldnt be the first time
Processor, ram, video card are fine, power supply too. All tested on other mobo and no issues.
check for 5V 12V rail resistance on the motherboard
I already replaced caps but no go.
waste of time on this vintage , caps were all fine
what I can see is a POST card with a "REAR ->" printed on it plugger wrong way
now its too late, you probably fried either post card or chipset
