Reply 20 of 20, by erpster-xg4
erpster-xg4
Offline
Horun wrote on 2023-05-17, 00:38:Also the archive of BIOSTAR has AWDflash 7.87D listed as the one, http://web.archive.org/web/20010827201207/htt … t/biosindex.htm
you can DL it straight from there... and here is yer BIOS page: http://web.archive.org/web/20010827212104/htt … pport/m5alc.htm
a 7.95 version of AWDFlash is available here in another forum:
https://www.wimsbios.com/forum/post70222.html#p70222
Yes, Awardflash 8.xx is definitely the issue here. These newer Awardflash versions can give strange problems on older boards.
For Socket 7 boards you need Awardflash 7.xx. I'm using Awardflash 7.95 and this version works fine here, on any socket 7 board with Award BIOS, except Asus. (For Asus socket 7 use Aflash 2.02).
