Reply 20 of 29, by ediflorianUS
maybe it's not the gpu , maybe it's not getting enough power (I am just thinking out -loud) , did you try without the 4 pin plug? or cold solder joins at the 4 pin connector... hmm . So many things to check . it's definitely a project.... I would probably Recap the card first.... (after the hot iron thing before the reflow) those 470uf 10V may seem fine but may not be ... however you need skill to change them all.
My 80486-S i66 Project
Reply 21 of 29, by shevalier
ediflorianUS wrote on 2023-06-04, 09:56:
LE. BTW most of the times if GPU is 100% blown it won't have power on the fan rails , so I am not sure that it's 100% dead. (it's a good sign you have power on fan rails).
Nope.
The old design Radeon 9800 is based on APW1175, which is powered by two phases of 3.3 and 5V.
The fan is powered directly from the 12V bus.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 22 of 29, by shevalier
ediflorianUS wrote on 2023-06-04, 10:46:
Again no.
There is a diode from the 3.3V bus to the 5V phase.
When an additional wire from the PSU is not connected, about 2.7V comes to the second phase and the GPU starts up.
Depending on the VBIOS, it either issues a warning and stops, or continues to work as if nothing had happened.
PS. It all starts with measuring the voltages coming to the card and after the converters. And not in poking a soldering iron into a GPU.
Reply 23 of 29, by ediflorianUS
shevalier wrote on 2023-06-04, 11:12:
Again no. There is a diode from the 3.3V bus to the 5V phase. When an additional wire from the PSU is not connected, about 2.7V […]
Again no.
post a picture with the converters circled so we all learn something.
Reply 24 of 29, by shevalier
This?
https://fccid.io/M698836/Schematics/Schematics-414550
page 21
or this?
download/file.php?id=165581
page 8
Diode from rail to rail - is D25 for 9800 pro old design.
And most importantly, ***, in which no one believes.
    119.73 KiB
Reply 25 of 29, by Pino
Played a little more with my dead 9800PRO AIW this weekend and stil can't figure out what is wrong, using a PCI card in conjunction I can see the 9800 is recognized in Windows and even by the Catalyst driver. Using ATI DOS flash tool I was able to access it, save the original VBIOS and flash a VBIOS I downloaded from techpowerup. Computer boots but no signal on the monitor, it only has a DVI conector, so I used a DVI-HDMI to my monitor.
Anyway, very different issue from OP's apparently, I don't wanna hijack his post, just sharing my pain with another 9800PRO.
Reply 26 of 29, by ediflorianUS
Pino wrote on 2023-06-05, 17:17:
AIW has TV tunner on it , will that chanel posts into the TV turner app? (instead of DVI monitor maybe you should try mounting a old compatible TV , CRT or old LCD).
Reply 27 of 29, by ediflorianUS
Looky what I found today (I totally forgot I had in a few shue boxes - from my old GPU collection , probably need's fixing ) :
PowerColor CN-R98-PC3B-1B-467-005K A00 - so that's a Radeon 9800 Pro right? (unknown status)
Black PCB Sapphire(has a hologram?) - Radeon 9800SE 128M DDR V/D/VO - samsung 434 memory R360 chip
Radeon 9800 Atlantis (It's calling...) 128M 128-bit DDR V/D/VO - hynnix 411A memory R360 chip
Reply 28 of 29, by The Serpent Rider
Powercolor and Atlantis - probably dead GPU. Sapphire with Black PCB could be repairable after memory replacement.
Reply 29 of 29, by ediflorianUS
The Serpent Rider wrote on 2023-06-16, 15:35:
Powercolor and Atlantis - probably dead GPU. Sapphire with Black PCB could repairable after memory replacement.
Tnx , I will check in the day's to come.
