Amd k6-2+ won't run higher than 66 mhz
Reply 20 of 62, by Florian J
dionb wrote on 2023-07-26, 18:58:
Florian J wrote on 2023-07-26, 18:22:
Alright so I got a Pentium mmx working on the motherboard again, I will update the bios to the latest version and if that doesn't help I'll use Jan Steunebricks patched bios.
Thanks for all the help 👍
The latest official version does not support K6Plus CPUs, so that will not change behaviour. That's why Jan has patched the BIOS.
For what it's worth I have the similar Tekram P5MVP-A4 motherboard and behaviour was exactly the same before flashing the patched BIOS. Afterwards it happily ran with my K6-3+ CPU.
Yeah I thought that updating the official bios would probably not change anything. I'll just use Jan's patched bios then, also thanks for the info 👍
Reply 21 of 62, by Florian J
dionb wrote on 2023-07-26, 19:59:
kixs wrote on 2023-07-26, 19:11:
Tekram P5MVP-A4 is not similar board to P5TX-Bpro at all.
Not P5TX-Bpro, but the P5M4-M+ OP was talking about first and that he is actually trying to get the CPU working on now, after finding it boots on the P5TX-Bpro but that one overvolts it badly.
MVP3 full ATX vs MVP4 uATX, but otherwise both similar last-gen (S)S7 platforms from Tekram with very similar BIOS with the exact same BIOS limitations that are fixed by Jan's patch (K6Plus and 64->128GB HDD limit)
Actually the P5TX-Bpro just overvolts by 0.1 volt, while the Tekram P5M4-M+ overvolts it by 0.2 since it can't go lower than 2.2 volt and the AMD K6-2+ is rated for 2.0 volts.
Reply 22 of 62, by Florian J
gerwin wrote on 2023-07-26, 20:07:
Florian J wrote on 2023-07-26, 17:30:
I think I found the issue. The motherboard does not support 2.0 cpu voltage, which is what the cpu is rated for.
The first board you mentioned, P5M4-M+, seems to support 2,0V as the minimum. With all jumpers removed that is. Not directly illustrated as such, but it figures.
In general though, for socket 7: When you are unsure of CPU voltage settings, then don't try anything until you are sure. You can fry your Voltage-Regulator and/or CPU with the wrong setting. It is not user friendly like more modern motherboards.
I didn't know that you could remove all jumpers to get 2.0 voltage. I'll try that out tomorrow, thanks for the useful info 👍
Reply 23 of 62, by Sphere478
2.0v is usually all voltage jumpers removed
If the mobo won’t post after changing settings try a cmos clear I’ve run into that when changing cpu settings on ss7 boards
Showing 486 dx or pentium 66 or other weird things like that is typical when the bios doesn’t fully support the cpu
Look for a jan bios. (I think someone already mentioned)
Yes, 2x=6x
Your bios reported speed can’t be trusted, read it in software.
Sphere's PCB projects.
Reply 24 of 62, by Florian J
Alright so I'm now ready to update my bios with Jan Steunebrinks patched bios, I'm just wondering if I should update to the newest version of the official bios first or if that doesn't matter.
Reply 25 of 62, by Florian J
I've now installed Jan's patched bios and the motherboard detects the AMD k6-2+. I'm running it at 2.2 volt because the pc doesn't want to post if I remove all the jumpers to get 2.0 volt.
Reply 26 of 62, by Sphere478
Florian J wrote on 2023-07-27, 10:36:
2.2v should work
It is likely that all removed is giving you 1.3v or around abouts. Some mobos do that.
Try seeing how high you can set the clock on the cpu now.
You should be able to do 550-650mhz a common config is 100x6 =600
I forget if your mobo has 100fsb though.
Edit: okay I see you have a 430tx mobo those are usually good for 75-83mhz fsb if they allow you to set it.
So you should be able to get 400-500mhz out of the cpu.
Do some tests, it may be faster with mobo L2 disabled.
Disable system bios caching
Which model of 2+ do you have? See my sig about unlocking to 3+
With the 2+ you should be able to upgrade to 256mb of ram
Reply 28 of 62, by Florian J
Sphere478 wrote on 2023-07-27, 11:49:
2.2v should work […]
2.2v should work
Yes 2.2 volt seems to work fine. I've tested setting the FSB to 100 mhz and the multiplier to 5.0 giving me 500 mhz and that worked without any issues. I'm now using 5.5 multiplier and it works fine as well. 5.5 is the highest the multiplier on the P5M4-M+ motherboard will go, but I can set the FSB to 124 mhz. Also I have 256 mb of ram. I will do some stress testing with CPU-Z to see that it's stable.
Reply 29 of 62, by Sphere478
kixs wrote on 2023-07-27, 11:56:
OP has P5M4-M+. It supports 100MHz FSB.
Okay, I saw a model earlier in thread, must have misunderstood
So OP should be able to do something in neighborhood of 550-600mhz most likely
Edit: set cpu to 2x on the motherboard and see what speed that gets you 😉
Btw, I’ve messed with these systems a lot and programs run much faster and better with 9x/ME
At the very least, don’t use xp sp3 use rtm
Reply 30 of 62, by kixs
Florian J wrote on 2023-07-27, 12:14:
2.2v should work
When you setup the CPU multi to 2X on the motherboard. It will set internal CPU multi to 6X.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 31 of 62, by Florian J
Sphere478 wrote on 2023-07-27, 12:15:
Okay, I saw a model earlier in thread, must have misunderstood […]
Thanks for the advice, I'll try running the cpu with the multiplier set to 2x. As for my choice of operating system, i just prefer using Windows xp since its what im the most familiar with. Also perfomance wise it runs very well in my opinion + i dont plan on using this system for gaming but rather as a retro daily driver.
Reply 32 of 62, by Repo Man11
Another computer working thanks to one of Jan's excellent patched BIOS! When I first set up my Asus P55T2P4 with a K6-2+ in 2001, it worked well enough with the original BIOS (It was stable and had no issue with POSTing with the Asus BIOS), but then I discovered Jan's page and updated it to a BIOS that he had patched to support the plus series K6-2. I appreciated having the correct CPU identification, but the more important part (which I didn't fully appreciate at the time) was that it enabled write allocate with the plus series CPUs.
Reply 33 of 62, by Florian J
Repo Man11 wrote on 2023-07-27, 14:06:
Yeah i really appreciate Jan's patched bios, does he accept donations? Also thanks for providing me with the links to the websites 👍
Reply 34 of 62, by Sphere478
Florian J wrote on 2023-07-27, 13:09:
Not sure what you plan to do with it but if it involves modern internet. It won’t work. You need a modern cpu for that. You need the instruction sets
Reply 35 of 62, by Florian J
Sphere478 wrote on 2023-07-27, 14:29:
Im not sure what to do with it either. But I don't play many video games especially not any that would run on hardware this old. So I thought I could use it to watch anime if thats possible. It doesn't have a graphics card in it right now but Im planning on buying one at some point.
Reply 36 of 62, by Sphere478
You would have to use old codecs and players. But if you found or converted to videos that would play back then, it would work. Again, probably smoother playback on a lighter OS
I used to use a k62+-450 as a dvr to record and watch tv on windows mce. It barely worked
Reply 37 of 62, by Florian J
Sphere478 wrote on 2023-07-27, 14:47:
I have tons of dvds and the pc has a dvd rom so it will probably be fine.
Reply 38 of 62, by Repo Man11
The onboard ATI Rage isn't terrible, but there are many PCI graphics cards that would improve performance. Another operating system to consider would be Windows 2000; it has most of the things that people like about Windows XP, but its hardware requirements are a little lower.
Reply 39 of 62, by Florian J
Repo Man11 wrote on 2023-07-27, 14:52:
Yeah the only problem is I can't find any that work with the PCI slot that's on the motherboard. I will consider installing Windows 2000 or 98 SE.
