Netburst: Aiming for the Stars
Reply 20 of 523, by H3nrik V!
So, a Willamette core Celeron would also be allowed? I know it's not s fast per MHz, but maybe the overclockability is better and thus could push past it's P4 siblings?
Reply 21 of 523, by supercordo
H3nrik V! wrote on 2023-11-05, 19:16:
Yes, The Willamette 128 core is allowed.
Reply 22 of 523, by Horun
Great ! will dig my 1.7 celery out and check if that 2Ghz one is a willamette. Now to try find a board in the stacks o crap to run it on 😀
think the SL68F was the only s-spec for Willamette 2.ghz celeron and not finding any online for a reasonable price
Reply 23 of 523, by acl
I guess i'm first to give it a try !
Probably not super spectacular but here are my setup and results :
  • Socket 423 P4 Willamette 1.7Ghz @1850 (17 x 109fsb)
  • MSI 850Pro2 (the one with a ram slot parallel to the AGP/PCI slots)
  • Zalman cooler attached with zip ties
  • 2x 256MB RDRAM 1066 (Running as 800 because of the motherboard)
  • XFX GeForce 7900 GS 512MB AGP @550Mhz core & 800Mhz mem
Does this system match the requirements ?
The attachment IMG_20231106_002238.jpg is no longer available
I'm getting :
  • 3DMark 2000 : 7048
  • 3DMark 2001SE : 11330
The attachment 3DM2000-1850-550-800.png is no longer available
The attachment 3DM2001SE-1850-550-800.png is no longer available
The system seems quite CPU limited because i could not improve the scores after another GPU freq. increase (550 -> 590). It even resulted in a slightly lower score.
I could not overclock the CPU more. The BIOS offers no overclocking options at all. Everything was set using a software under windows (FuzzyLogic) that crashed the system after each fsb modification (but rebooted with the new value configured). No other options such as voltage or AGP/PCI freq. Probably not the best motherboard for that.
I wanted to try a RadeonHD 3850 AGP at first, but the motherboard refused to boot with it.
Reply 24 of 523, by Horun
Nice ! I will not have such a well rounded system to test on, will have to use parts not already in systems.
Reply 25 of 523, by supercordo
acl wrote on 2023-11-05, 23:29:
I guess i'm first to give it a try ! […]
I'm getting :
Its on the board!!!
Reply 26 of 523, by H3nrik V!
Wonder how GPU bound these benchmarks are. The fastest AGP card I have is a GeForce 4 Ti4200 ...
Reply 27 of 523, by supercordo
H3nrik V! wrote on 2023-11-06, 08:20:
It really depends on driver overhead from my experience.
Phil did a really good video about nvidia drivers. https://youtu.be/HRhm4aGNI3o?si=N7QpRL1HyHsOR7na
Reply 28 of 523, by acl
Horun wrote on 2023-11-05, 23:35:
I only have 3 or 4 "permanent" setups installed in cases.
For other usages i have one motherboard per socket "ready to use". With CPU + Cooler + Ram installed permanently.
Fresh OS images for CompactFlash cards saved for each system. I only have to write the image to CF, install a GPU / SoundCard and the system is running in just a few minutes.
supercordo wrote on 2023-11-06, 00:37:
Its on the board!!!
Thanks !
Reply 29 of 523, by Standard Def Steve
Ooh, I may have to dust off the old curbside Dimension 8100 for this. I actually can't remember if it's a 1.3 or a 2.0 - I just remember it being either the slowest or the fastest of S423 when I found it a couple of years ago. 😀
I believe Asus made a 915 based S478 board. It'd be neat to seat a Willamette in one of those and let 'er rip alongside an RTX 2080 Ti.
"A little sign-in here, a touch of WiFi there..."
Reply 30 of 523, by paradigital
I’m waiting for my Willamette 1.9 to arrive before I can get in on the action. Only ever owned Northwood and newer P4s before.
Reply 31 of 523, by supercordo
paradigital wrote on 2023-11-06, 17:59:
I'm out of town this week for work. I'll get to play this weekend.
Reply 32 of 523, by waterbeesje
Nope, not even going to try. 1.4GHz, 128MB ram and GeForce 2 MX200 just won't cut it. I'm protecting the poor thing against being bullied by the big guys.
:p
Stuck at 10MHz...
Reply 33 of 523, by Meatball
waterbeesje wrote on 2023-11-06, 19:17:
:p
No one's going to bully you - toss it up there. It's going to be fun!
Reply 34 of 523, by VivienM
:p
This is your excuse to go to eBay and pick up that 2.0GHz Willamette that motherboard has been dreaming of for two decades!
Reply 35 of 523, by VivienM
Standard Def Steve wrote on 2023-11-06, 16:31:
Somebody already inventoried all these boards - Socket 478 Motherboards with PCI-E Slots . Maybe I'm missing something but I can't see which ones the OP identified as not supporting Willamette.
I did check the supported CPU list for the Asus P4GD1, no Willamettes listed... 🙁
Reply 36 of 523, by Horun
:p
Hahaa I am going with my only Willi a 1.7G Celeron if the board supports it and a Geforce 3. Am sure will be down in a benchmark list but will give it a try 😀
Reply 37 of 523, by BitWrangler
Horun wrote on 2023-11-07, 00:15:
If you are quick of the mark you might be able to squeak 13-16,000 out of it fully wrung out and look pretty good until the 6800 and ATI x series crowd wakes up.
Reply 38 of 523, by Standard Def Steve
VivienM wrote on 2023-11-06, 23:04:
Aww, that's no fun. But a Northwood Celeron would be just as slow (or worse, even) so I guess the bottleneck fetishist with one of those boards could take that route. 😜
Speaking of which, the Willamette and Northwood Celerons are excruciatingly slow in 3DMark 2000. There's just something about that benchmark - I guess the data sets just don't fit at all into 128K. I kid you not, a 1GHz PIII will legit outperform a 2.6GHz Celeron in 3DMark 2000.
Reply 39 of 523, by Horun
Standard Def Steve wrote on 2023-11-07, 00:35:
Hmm ok so what about Celeron and 3DMark 2001 ?
