Horun wrote on 2023-11-25, 16:42:
Great you figured it out. maybe you could try a pci add-on usb card to use the thumb drive, check the listed ones here: Which USB 2.0 cards for old motherboards
Thanks mate! Hey hold on.. i actually have a PCI-USB card!! 😮 gotta find where i put it but should be right here in my room between the box-o-stuff things. Nice idea!
But...didn't them need a driver? Or better, i can use that card to install\use USB without it takes all those precious IRQ that the motherboard does? Sorry but im so noob about it...bad part is that being a PCI card i have to put the sticks behind the case, which is a little bit uncomfortable (i was using the front two usb's ports of the case, with that grey cable that goes directly to the motherboard)
Will try to find that card and post it here so maybe i can find the drivers, hoping it will work for Win98! Thanks 😀
ASRock 939S56-M
AMD Athlon 64 4000+ 2.40Ghz San Diego\Toledo (Single Core) 1000Mhz HT FSB
1024MB DDR400 Dual Channel (512x2)
ASUS Nvidia GeForce 6800 GT PCIex 256MB GDDR3
ESS Allegro-1 (ES1989S) PCI
Win98SE+XPSP3+VistaUltimate
HP 56 15" CRT
