SB PnP 32 CT 3620 and DOOM 1 sound issue
Reply 20 of 30, by CoffeeOne
dominusprog wrote on 2024-01-06, 16:28:
Decrease the ISA bus speed, second screenshot. Right now the ISA is working at 16.5MHz, 66/4=16.5. […]
ISA Bus Clock Option : PCICLKI/6
Also increase the keyboard controller clock.
Keyboard Controller Clock : 16Mhz
Are you sure about that?
Internal clock = 66MHz on this board? Really?
Then the correct setting for ISA would be /8
Reply 21 of 30, by digistorm
On a DX/2 the bus would be running at 33.3 MHz and so also the PCI bus. /4 is a normal divider for a 33 MHz bus and would result in 8.33 MHz ISA bus.
Reply 22 of 30, by Cadderlik
So I should leave PCICLKI/4?
Reply 23 of 30, by CoffeeOne
Cadderlik wrote on 2024-01-07, 09:37:
I think so, yes.
What is also wrong then is the ratio Host clock / PCI clock. It is now 1: 1/2 according to your screenshot.
That would mean PCI bus is running out of specification (16MHz), it is below the allowed minimum, which is 25MHz as far as I know.
So => 1:1 then it should be 33MHz. graphics should be again faster.
Now when I think about it, when your PCI clock is now 16MHz, then the ISA clock would be only 4 MHz now? Weird.
Reply 24 of 30, by Cadderlik
Nowe Set 1:1, somehow bios changed it. Sound issue still in Doom like.
Reply 26 of 30, by Cadderlik
Tomorrow I'll try and give an info. I will also check another keyboard with oryginal din. Now Im using PS2 with adapter.
Reply 27 of 30, by dominusprog
CoffeeOne wrote on 2024-01-06, 22:02:
Are you sure about that? Internal clock = 66MHz on this board? Really? Then the correct setting for ISA would be /8 […]
My bad, I thought it divided the internal clock.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 28 of 30, by Zerthimon
Has anyone mentioned the "Turbo" button yet ?
Reply 29 of 30, by Cadderlik
Turbo is ok. Speed is eqal to dx2 in benchmark.
Reply 30 of 30, by CoffeeOne
Cadderlik wrote on 2024-01-07, 18:40:
So what is the status now?
Everything is fast only the sound in doom is not working? Is it correct?
Did you try unisound?
