Reply 21 of 45, by hilram
Installation
Motherboard installed
PCI Riser
Fits snugly round the back, perfect!
PCI Graphics Card
OOPS! Looks like we hit a snag!
Anybody spot the problem?
It seems like the case orientation of the graphics card is "Upside down" if we were to route the extension cable the shortest, most logical route. As it stands, I can't secure the cards to the case.
This is one I did not see coming! Anybody out there who has faced (and overcome) the same?
Reply 22 of 45, by Tevian
Ya!! 🤪 Maybe you can find a longer extension? That sucks though...
Reply 23 of 45, by elszgensa
That's what you get for trying to install those cards with the heatsinks pointing inwards.
Reply 24 of 45, by hilram
Tevian wrote on 2024-04-28, 11:21:
Exactly! To make matters worse, my extension cable cost almost as much as the case, and they don't accept returns!
Reply 25 of 45, by elszgensa
Hey at least the cables aren't soldered, which would be annoying. They seem to be repurposed IDE cable connectors, which are readily available and you can easily DIY the longer cables - just crimp them on, e.g. in a vice.
Reply 26 of 45, by hilram
elszgensa wrote on 2024-04-28, 11:33:
I guess that is certainly a viable option. Only question is if the signal integrity will hold if I quadruple the length of the original cables.
I guess I have three options:
1) Try to replace cables with longer ones
2) Try to re-orient the PCI-card mounting bracket 180 degrees
3) Hack the case and the mounting bracket (pliers + drill)
I regard option 1 as the most complex, but in turn that would give the most satisfying result. Still there is a risk I will stop the PCI riser from working, either because the cables simply cannot be that long, or because of my own ineptitude.
Option 3 is the easiest fix, but will of course be ugly. And I will always know!
Reply 27 of 45, by Dothan Burger
hilram wrote on 2024-04-28, 11:48:
I guess that is certainly a viable option. Only question is if the signal integrity will hold if I quadruple the length of the o […]
I would first test the riser outside of the case and see how everything works. If signal integrity becomes an issue maybe you can attempt the shielding technique that ahmadexp used in the ITX Llama thread where he wrapped the riser cable in copper tape.
Reply 28 of 45, by hilram
Yes, I suppose that is how I will go about it. But I have decided to order a new extension cable:
20 cm 32-bit PCI M to F connector
Ordered it from AliExpress, I hope it will work with daisy-chaining my one-to-two PCI extender. If not, I will have to use this one on its own, and sacrifice a second PCI-card.
That means giving up on EITHER
1) Positional audio, and instead rely on the Southbridge on-board sound instead OR
2) A Vooodoo 2-card for native Glide support.
Will also have to probably 3D-print a custom support for some kind of PCI-holder. My job has a couple of 3D-printers we can use for personal use if we ask nicely.
Reply 29 of 45, by Shponglefan
A 3D-printed bracket would probably be the most elegant solution for mounting the bracket upside-down
edited: Just saw you mentioned 3D printing in your most recent post. 😅
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 30 of 45, by hilram
Of course, I could always 3D-print new brackets for the cards! Why didn't I think of that? Anyway, I have ordered that 20 cm extension cable, will try that first. Will keep you posted how things are going. PSU will arrive in a few days, will power on and connect it then.
Reply 31 of 45, by Dothan Burger
hilram wrote on 2024-04-29, 11:31:
So how did this turn out? Can two devices share the same PCI port and not cause issues?
I bought that DELL P1917S and it turns out it's huge piece of crap. The screen doesn't look like anything like an IPS, a TN panel would look better in my opinion. Couldn't get any refresh other than 60hz to work. I took a chance and I wouldn't recommend it.
Reply 32 of 45, by Fish3r
I'd be interested to see how well that riser works, I've got a similar system that I want to move into one of these sandwich cases so full height cards can be used with it.
Reply 33 of 45, by hilram
Sorry for the abscence! Work was crazy up until the start of the summer holiday, but now I am back home, and free.
YES everything works! Even with the PCI Riser and the PCI Extension cable Daisy-chained! I am very happy with that! Tomorrow I will plough on with attempting to install Windows 98 on the machine. So stay tuned!
Reply 34 of 45, by hilram
Dothan Burger wrote on 2024-06-03, 03:25:
Oh My! Really? Thanks for the warning, I will reconcider then... I mean, even if you use the analog VGA input, still only 60 Hz?
Reply 35 of 45, by Dothan Burger
hilram wrote on 2024-07-09, 15:57:
Yes even the VGA could only handle 60hz from my 7950gt in 98 and XP. I might have to bring it out again for a round 2 of testing as Dells website says I'm wrong. The big issue for me was that it looked so bad compared to my CRT.
Reply 36 of 45, by hilram
It could be that it is not communicating its VESA modes properly to your graphics card. It might need actual monitor drivers for the right modes to be available. With "Generic PnP monitor" driver it might never give you anything other than 60 Hz. See if you can download an appropriate monitor driver from Dell, and then force the driver in Device Manager.
Reply 37 of 45, by Dothan Burger
hilram wrote on 2024-07-10, 13:46:
75hz does work, what was confusing me is that the info section of the OSD says 1280x1024 60hz max but to the left it shows 75hz is working. Doesn't seem to make it feel much faster, just moving the window around feels terrible even with fast pixel response enabled. DOS gaming is working so I might just bring it to the next LAN party. I certainly won't be using it day to day.
Viewing angles seem poor compared to my other IPS panels.
Reply 38 of 45, by hilram
Finally picking up this project again.
I am having some bad problems with getting an OS installed.
I had several IDE drives stored in boxes, lord knows from when, and all turned out to be broken. So I decided to go the SD card to IDE-adapter route. Ordered one of these from AliExpress:
It seems erratic. First, the mainboard would not detect a HD at all. Then, I tried switching to a different SD card. A SanDisk card with 2 GB capacity was detected. But then after a reboot, not detected. Since I had some success with the SanDisk SD-card, I decided to go for a SanDisk 32 GB card, and forget about my "no-name" card.
But alas, that won't detect either!
I have tried to switch from first to second physical connector on the IDE cable. However, there is no place for me to set master/slave etc, so it is really limited how much I can tinker with it. But from what I am reading on this forum, these adapters just work...
I guess trying a different IDE cable will be next, but it was this one that came with the MB.
Reply 39 of 45, by such
I have a couple of these adapters and for some reason they... prefer 128GB cards. They have issues detecting smaller cards, including 32GB, but 128GB is reliably fine, tested across multiple different cards and manufacturers. These days I just use that capacity exclusively, partition the card, and I keep slave unused.
