Dos 6 conventional memory tricks
Reply 200 of 298, by johnsonlam
Hi,
Try replace all the DOS driver with Jack R. Ellis driver, you may have surprise.
1) QCDROM.SYS was very old, seriously outdated, try XDVD2.SYS
2) XHDD.SYS replace SMARTDRV.SYS, it's faster! It had Read-Ahead, DMA/caching overlap, and other new updates. XHDD also offers caches down to 2.5-MB, for 386 users."
3) HIRAM.EXE, please use latest UMBPCI.SYS with XMGR.SYS on Pentium-1 and later systems supported by UMBPCI.
4) MAMMAKER, QEMM, don't need them anymore. Use JEMM386 available in the FreeDOS files on SourceForge IBiblio."
5) MSCDEX, I use SHSUCDX, Jack R. Ellis version (since Jason Hood gone) which work fine.
Wish everyone can play games or using DOS happily without the old and worn drivers.
http://optimizr.dyndns.org/dos/drivers.html
Rgds,
Johnson Lam.
Reply 201 of 298, by GigAHerZ
How can i get EMM memory without EMM386/QEMM?
Reply 202 of 298, by johnsonlam
You can get JEMM386, available in the FreeDOS files on SourceForge IBiblio.
Reply 205 of 298, by Caluser2000
Get a system that can allocate EMS in its bios setup routine like my Zenith Z286LP Plus.
Reply 208 of 298, by BloodyCactus
loads of EMS ISA cards. heaps for xt + 286.
Reply 209 of 298, by Caluser2000
oeuvre wrote:
Never even heard of EMS ISA cards... those exist?
I've got one that takes 8megs of dimms. They were widely used late 80s.
Reply 212 of 298, by Nemo1985
Sorry for the (relative) bump.
I'm playing with dos and I'm trying to make an image with config.sys and autoexec.bat fully optimized, I did try to use memmaker but it makes things worse.
The maximum result I was able to achieve is this one, 624kb free conventional memory and 136kb upper memory.
I'm not using umbpci and other tricks since I'd like this to work even on 486 system.
Here is the mi output:
Addr. Low area High area Program or device driver ----- -------- --------- -------------------------- 020Bh 1,024 […]
020Bh 1,024 .. IFS=
024Ch 1,152 .. Device=HIMEM Attr=A000h Name=XMSXXXX0
0295h 4,160 .. Device=EMM386 Attr=C000h Name=$MMXXXX0
039Ah 544 .. IFS=
03EBh 639,296 .. <largest free area>
---- Begin High (Upper) Memory ----
B166h .. 10,032 COMMAND /F
B3EAh .. 3,088 CTMOUSE
B4ACh .. 6,144 SHSUCDX
C803h .. 8,288 Device=DISPLAY Attr=C053h Name=CON
CA0Ah .. 5,008 Device=VIDECDD Attr=C800h Name=OPTICAL
CB44h .. 464 IFS=Can't in
CE0Bh .. 6,928 KEYB IT,,C:\DOS\KEYBOARD.SYS
CFBDh .. 4,672 DOSKEY
D0E2h .. 29,104 SMARTDRV C+ /N /Q /U
655,360 bytes (640k) total DOS 7.10 conventional memory.
639,296 bytes (624k) largest executable program. 131,104 bytes if loaded high.
EMM386 is present. High memory is managed by DOS.
0 bytes Extended (AT/286/386) memory, reported by BIOS.
2,631k bytes XMS 3.0 (3.65) memory: 2,632k used + 65,535k free. DOS in HMA.
384k bytes EMS 4.0 memory: 384k used + 0 free. No page frame.
Note: with no page frame, some programs will not detect or use EMS.
Considering it's without any sound driver but with mouse and cdrom driver and smartdrv, is it ok?
Thanks in advance.
    files.7z
    890 Bytes
    111 downloads
    autoexec.bat and config.sys
Reply 213 of 298, by GigAHerZ
@Nemo1985, you can use RDOSUMB, URAM or something similar instead of UMBPCI. Those are written in the nineties and support way older machines like 386 and 486.
Reply 214 of 298, by Nemo1985
Thank you for the tip, I will check them, on the other hand I wonder are they really necessary? Is there any program who needs more than 625kb of conventional memory?
Reply 215 of 298, by Caluser2000
600k is adaquate for the vast majority of Dos software. Having a lot of free conventional memory can also confuse some Dos applications.
Reply 216 of 298, by Nemo1985
Thank you so there is no need to hunt for more conventional memory.
Reply 217 of 298, by gdjacobs
I usually shoot for about 610k. It seems to be sufficient for pretty much everything.
