Retro Rig Photo Thread
Reply 200 of 3356, by ibm5150pc
DELETED
Reply 202 of 3356, by ibm5150pc
DELETED
Reply 203 of 3356, by GXL750
The PS/2 looks very nice. To think that thing was quite the beast in the late 1980s. I also like that Compaq 486 system visible in the photo of the Gateway.
Reply 204 of 3356, by ibm5150pc
DELETED
Reply 206 of 3356, by ibm5150pc
Yup, the place were I was hosting them is going bye bye ;-(
Tetrium wrote:
ibm5150pc wrote:
DELETED
Any reason why you deleted all of your posts here??
Reply 207 of 3356, by sliderider
I wish my GX1's looked like this one
And it has upgrades.
"Inside, you'll find an Intel Celeron processor (1.4-GHz), 512MB of RAM, ATI Radeon 7000 graphics, 80GB HDD, and a Dell GX1 motherboard"
Upgrade the video card and a little more RAM and you could run Windows 7 on it. 😁
http://www.techeblog.com/index.php/tech-gadge … dell-gone-wrong
Reply 208 of 3356, by sgt76
Man, that looks ricey, though I can appreciate the work and thought that went into it. Matter 'a taste I suppose.
I think a retro rig looks better if it stays retro looking like bushwhack's P1 and P3 builds, Old Trashbarg's Athlon, Tetrium's entire attic....
Reply 209 of 3356, by stano
Hello crowd,
this final PC I have is my first computer I bought in 1996.
It is an Acer Aspire with a V12LC-2x mainboard which funnily enough is a socket 5 m/b.
It originally came with a pentium 100 mhz cpu , 8mb of Ram, a cirrus logic 5434 integrated video card with 1 mb of ram a 1.2g hard drive, 6x cd rom and finally a soundblaster 16.
Monitor is a 15 inch acer 7156s.
This was the new wave of "multimedia" pc's that had windows 95 installed and you could see videos, play games and do your homework like never before, according to video of the lady that come up after you first booted the pc. She went to talk on about "oobe" the out of box experience of owning an acer aspire pc.
The reason I bought the pc was because it was green. Every other pc was beige and for an utter newb like me in 1996 (the black pc revolution was a few years away) thats what had me hooked.
The games I played on this pc are too numerous to mention, but it is this memory that stopped me from junking the pc years later. After all you don't junk what you loved so much!
In the mean time here are some pics:
http://www.flickr.com/photos/61324868@N02/579 … in/photostream/
Now in the intervening years I have upgraded the pc a bit.
Having a propriety mainboard stopped any possible uprgade of the board.
However the cpu was changed to a p166 and then overclocked to 200mhz where it stays today.
Ram was increased to 86 mb. A nice increase.
The 1.2G quantum hd failed and was replaced by a 4.3g seagate.
A matrox millenium 2 pci card is doing the 2d duties. This card has the daughterboard vram expansion with overall 8mb of vram.
A voodoo 2 12mb is doing the 3d.
and a realtek pci nic is connecting the pc to the network.
motherboard, cpu, ram
voodoo2
these old pc's should never be thrown out. Just used as they were meant to be..
so here is to all the memories!
Reply 211 of 3356, by stano
the fan is very quiet actually. if it goes I will have a hell of a time replacing it. the heatsinkfan is glued onto the cpu!
Reply 212 of 3356, by Tetrium
You can remove the fan though, it's mounted with some clips. The heatsink is glued indeed.
My retro rigs (old topic)
Report spammers here!
Reply 213 of 3356, by sgt76
My old P3 "Rat Rig" in a new old case. Everything is period correct to 99/00- looks it though don't it? 🤣. Cosmetically a bit worse for wear but it runs very nicely.
A very old case from 97 with removable PSU mounting and motherboard tray.
Specs" P3 800Mhz, Matsonic MS7112C mobo, 384mb ram, Voodoo3 2000, SB AWE64, 3C905c-tx, 10.8gb hard disk, 40x cd-rom, Win98SE with SP2.1
Voodoo 3 is overclocked at 166mhz- capable of 190mhz but best to keep things within check. Cooled by a 40mm fan, and a PCI slot fan underneath it. Plus an 80mm intake fan up front. Temps are OK thanks to this.
A closer look. This is a very sensitive motherboard, took me a long time to figure out settings and hardware that works in combination with it but it's running along nicely now. 133mhz fsb but the ram is set at 100mhz CL2 Turbo. Running the ram synchronously is sometimes unstable- a problem I've seen with this and some other VIA 694A motherboards. The later 694X doesn't have such issues though and also runs great with any hardware you care to throw into it.
Playing DKII at the moment on this thing... never got to finishing that...
Reply 214 of 3356, by F2bnp
Wow that PCI fan is nifty. I've a small case like yours for my Pentium 3 and it gets quite hot in there. I might get one too!
Reply 215 of 3356, by sgt76
Put a pci slot fan in... works great on desktop systems too.
Reply 216 of 3356, by stano
I just remembered i have one of these pci slot fans...it was my first attempt at cooling my p3 450 rig. I later removed it as i wanted to use the pci slot...must try and find it..
sgt76
I see there is also a s370 socket, but you cannot use both the slot and the socket at the same time right?
Reply 217 of 3356, by sgt76
stano wrote:
sgt76
No you can't, and the socket is PPGA - that means Mendocino support only. These sorts of combo boards were popular cause they allowed you to use your old P2/ Mendocino and then hopefully upgrade to a Slot 1 P3 when prices dropped.
Reply 218 of 3356, by Tetrium
sgt76 wrote:
My old P3 "Rat Rig" in a new old case. Everything is period correct to 99/00- looks it though don't it? :lol:. Cosmetically a […]
Very nice! I have a case that looks vaguely similar, except iirc it has the PSU in normal position 😉
I've seen those combo Slot1/PPGA370 boards a few times and have 1 laying around somewhere and yes, you can only use 1 at the time.
The case looks ugly (shape, color, interior) but that's part of the charm really!! And the removable motherboard tray is a nice touch of course.
Well.....looking at the northbridge cooler, it looks suspiciously similar to the ones used on ECS boards 🙁
But if you've got it running fine (and the caps seem fine also) then there's nothing to worry about 😉
"Some" of those ECS boards are interesting though, often using the latest chipset hardly found on any other board because the major board manufacturers had already moved on to newer types of Sockets.
What would be interesting is finding the cases "little brother", often cases made in 1997 came in AT and ATX versions and looks very similar!
Edit:Btw, what PSU are you using?
Reply 219 of 3356, by sgt76
Thanks! It take a real connoisseur to appreciate the case.
It is an ECS board...Matsonic is one of ECS' various subsidiaries. I've had a few and not all of them are as bad as people say. I've had plenty of so called premium brand mobos go turkey 😵
That's me next project, an AT system... I've got everything else I want 'cept that. But systems that old are very rare here...most people here have a total throw out mentality with regards to anything old, be they computers, cars, etc.
It's an Enlight 250 watter.
