My 3DMark01 Mega Thread
Reply 200 of 840, by kithylin
Standard Def Steve wrote:
Damn, that's a great score for a C2D and 8800 on Vista--the worst performing OS (for 3DMark01) out there! […]
kithylin wrote:
Intel E7300 dual core (poor overclocker sample.. have to feed it tons of voltage, oh well), @ 4.0 ghz BFG water cooled 8800 GTX […]
BFG water cooled 8800 GTX (with small Overclock, +13% core, +12% memory)
Dual channel DDR2-1066 @ 1066 Mhz
Vista Ultimate x64
I've noticed that there are certain CPU architectures 3DMark01 seems to really like, and Penryn/Wolfdale is one of them. In fact, in 3DMark01 they seem to be as fast per MHz as Nehalem!
PIII Tualatin, Pentium M Dothan, and Haswell are also very 3D'01 friendly. Overclocked Tualatin slightly outperforms Thoroughbred at the same clock speed. Dothan easily beats Athlon 64 at equal clock rates. And Haswell, despite being only ~5% faster than Sandy/Ivy Bridge in most modern apps, manages to be around 30% faster in 3DMark01.
I believe it may be related to the processors' cache performance. While Thoroughbred has far more memory bandwidth available to it, the L2 cache is only 256KB and 64-bits wide. Tualatin may be stuck with PC133 on an antiquated SDR FSB, but it has 512KB of very fast (256-bit) cache.
Athlon 64 has extremely fast, low latency access to main memory, but its L2 cache is only 512-1024KB in size and 128-bits wide. Pentium M Dothan, on the other hand, has a 2MB, 256-bit wide cache.
Penryn/Wolfdale CPUs may lack an L3 cache and integrated memory controller, but they have 3-6MB of extremely fast, very low latency L2 cache. Nehalem's L3 cache is a bit slower than Wolfdale's enormous L2.
While Haswell's L2 and L3 caches are similar to Sandy/Ivy Bridge, the L1 cache is twice as fast, which seems to give it an edge in 3DMark01. Unfortunately, it doesn't seem to matter much in modern applications.
I had a.. what was essentially the fastest wolfdale dual core ever, but then I did a idiot thing and ruined it 😵 At least it was only a $23 chip today. I had a E3110, which is the 6MB version of the wolfdale dual core chips, and it was stable @ 4.65 ghz with only like 1.5v v-core, and then.. I did a stupid. I tried 'lapping' it with sandpaper, did it wrong, and it only made it run hotter. It still worked fine, but it ran so hot it was idle at like 70c in windows after that and I couldn't even do much with it. I still have the chip but doubt I'll be using it for anything. So.. I picked up this E7300 off ebay for $9 used. Works great.. it's just in comparison a really, really poor overclocker, takes a whole 1.66v just to do 4ghz. Doesn't really matter on water cooling, it just won't ever clock any higher.
What's the fastest quad core chip for 3dmark 2001 for LGA775? Penryn?
Reply 201 of 840, by kithylin
What's the fastest quad core chip for 3dmark 2001 for LGA775? Penryn?[/quote]
Reply 202 of 840, by AlphaWing
K6-2+500mhz
Fic PA2013 - Via 4in1 - version 4.49 - L3 Cache Disabled (it causes artifacts in 3d for some reason)
256mb sdram -2-2-2 100mhz
Geforce Fx 5500 PCI 256mb - 56.64 drivers
Direct X 9.0c installed
Windows 98se
3dmark2001 score =1949
Not the most amazing score, 🤣.
Reply 203 of 840, by kithylin
I dusted off my 6MB wolfdale dual core chip, put it in my 775 rig and fandangled with the settings some. It's too hot to run it above 4ghz (after what I've done to it) but after some fiddling I got it to run at a lower voltage and 3.8 ghz, tried it with the 8800gtx. And as it turns out, sure enough, the higher cache on the chip (6MB vs the 3MB I had before) sure seems to make a difference with 3dmark 2001se. 3.84 Ghz 6MB chip is apparently a little faster than the 3MB chip at 4.0 Ghz, even though they're both on the same core. New (better) score.
Edit: Vista x64 for this test. I would try XP on this machine but I don't have a spare hard drive anywhere.
Resized for the forums.
Full Size: http://www.outfoxed.net/2001se/E3110_@_3.84_G … 5_+_8800GTX.jpg
Reply 204 of 840, by m1919
Seeing this thread again really makes me want put some more vigor into my search for 900/2MB Xeons. With just the 700/1MB Xeons overclocked to 784Mhz, I was able to get 8000 points in 3dMark01 with an FX5950 Ultra. Would be interesting to see how 900/2MB Xeons overclocked to 1Ghz would stack up against a 1.4Ghz Tually running the FX5950 Ultra.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
Reply 205 of 840, by AlphaWing
Asus P2B-F, BX board, with a coppermine slot 1 PIII 700mhz 100mhzFSB
512MB PC133-@100-2-2-2
AGP Geforce FX 5700 Ultra, reference Nvidia branded card 56.64 drivers.
Guillemont Voodoo II 12mb last reference drivers.
5700 Ultra
3dmark2001 score =5786
3dmark2001 score =811
Tests done on.... Windows 98 se
Reply 206 of 840, by AlphaWing
Athlon XP 2600+ 166mhz FSB
MSI KT6V-LSR - VIA KT333 chipset 5.24a Hyperion Drivers
1gb DDR 333mhz 2-2-2 Timings
Pny Geforce 5900 Ultra 256mb AGP - 93.71 drivers
Yamaha YMF-724 PCI
250 GB ATA/100 IDE WD
WinXP-SP3
3dmark2001 score =12782
Reply 207 of 840, by AlphaWing
Dell Optiplex 330
Coreduo 2.4ghz 2 Cores
Radeon X800-PCIE-Cat_10.2
2GB DDR2-800-5-5-5
SB-Audigy Gamer
160GB 7200RPM Sata-I Segate
Windows Vista Ultimate X64
Score
3dmark2001 score =20411
Reply 208 of 840, by kithylin
You guys are getting me sort of inspired with this. Maybe tomorrow I'll get out my K6-III/550 and my geforce2, load it up with windows 2000 and see what it does with 3dmark.
Reply 209 of 840, by Liqu1d82
Matrox G400 on ASUS CUV4X-D, 2x PIII 800EB, 2x 128MB ECC PC133, Windows 2000 - latest legacy drivers from Matrox site, VIA4in1 for the chipset - is this result adeguate in your opinion?
Without change something sleeps inside us, and seldom awakens. The sleeper must awaken.
http://liqu1d82.tumblr.com [My Tumblr] // https://twitter.com/Liqu1d82 [My Twitter]
Reply 210 of 840, by Liqu1d82
My mothership @stock:
nVidia 9800GTX+ DK on ASUS P5B, Core2Duo E4500@2200, 4GB DDR2 @800 4-4-4-12, Windows XP
My mothership @3300 OC:
nVidia 9800GTX+ DK on ASUS P5B, Core2Duo E4500@3300 (300x11 - VCore@1.4), 4GB DDR2 @750 4-4-4-12, Windows XP
Reply 211 of 840, by AlphaWing
Nice ^ 9800GTX score.
I want to post the score of my current gen rig, but 3dmark2001 refuses to run in windows 8.1
Gives 128mb not detected memory error, no matter what compat mode I choose for it.
Reply 212 of 840, by LunarG
Liqu1d82 wrote:
http://s26.postimg.org/gdaw907ut/P_20140622_183424.jpg […]
Seems a bit low to me. I'm not really sure about the performance difference between G400 and G400MAX, but I got a score of 1718 on my Tully 1400 using G400MAX. Sure, that's a 400MHz faster CPU (doubt that version of 3DMark can really take advantage of the second cpu), but I wouldn't have thought the difference should be that big.
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 213 of 840, by AlphaWing
Pentium II 300 - Unlocked Space Heater
SOYO-SY-6KL - A BABY AT SLOT 1 motherboard LX based SOFT BIOS.
192mb PC100 @ 66mhz 2-2-2
AGP Voodoo 3 1000 8mb
Turtle Beach Montego II Aureal Based Sound Card PCI
Sound Blaster Pro CT1600
10\100 Intel Nic
X2 4gb ATA\33 Fuji hard drives.
8x NEC Cd-rom Drive
Win98se
Amazing Score of......
3dmark2001 score = 339
Could not Run at default settings, not enough Vram, even 800-600, while it ran textures were being dropped and turned into white blank sheets as it ran.
So 640*480 was the only viable setting.
Reply 214 of 840, by Liqu1d82
I doubt, in fact ... I do not understand where G400 lose performance, maybe some settings regarding the AGP in the BIOS of the motherboard.
Reply 215 of 840, by noshutdown
my p3s-1.4g+815e+g400max scores 1750 also. surely the coppermine-800 is not just a bit slower than the p3s-1.4g, and the via boards are not known for its performance either.
Reply 216 of 840, by Liqu1d82
Roger - so we can say this is a common result with my configuration... oh, well 😀
Reply 217 of 840, by AlphaWing
CPU matters alot in 3dmark2001
Look at my PIII 700, and the Voodoo II score, Then look at the PII 300- with the 8meg Voodoo 3.
Reply 218 of 840, by AlphaWing
Intel Celeron 333mhz
Gainward 6ILA - Intel LX mobo ATX. Yea Gainward actually produced a few motherboards surprised me too when I got it.
384mb PC100 @ 66mhz 2-2-2 Max motherboard supports
Hercules 3d Prophet II Geforce 2 GTS pro 64mb DVI edition AGP. Detonator 6.50 drivers
Diamond Monster 3d II - Voodoo II Last Reference drivers
Creative Sound Blaster Live! PCI
Labway ESS 1868f ISA
UMC 10mbit ISA nic
x2 Front Loading CF card IDE bays (Storage varies usually has a 32gb in the boot one.)
16x Sony DVD drive.
Win98se
3dmark2001 score = 575
Hercules Geforce 2 GTS Pro 64mb
3dmark2001 score = 219
Not, amazing scores, but again shows how cpu bound the benchmark is.
Reply 219 of 840, by noshutdown
AlphaWing wrote:
3dmark2001 score = 575 Hercules Geforce 2 GTS Pro 64mb http://i1074.photobucket.com/albums/w401/Alphawing9000/Celeron333_Geforce […]
this score is awful, sth must be wrong with your rig.
my celeron300a oc 450 and gf2ultra scores ~1600pts, and i don't think yours is only one third as fast as mine.
even my p55c oc 300 scores 640pts, and k6-3-300 scores 990, all using the gf2ultra.
