Reply 20220 of 27685, by zapbuzz
- Oldbie
zapbuzz wrote on 2021-10-23, 17:11:i got my retro pc in post yesterday been working on it. So far the gpu freezes, the ram is non matching pair of half capacity i […]
So far the gpu freezes, the ram is non matching pair of half capacity i bought
it has original windows 7 no sp
the foxconn motherboard based on via p4m800 chipset accepts Both DDR and DDR2 ram up to 2gb
the built in chipset graphics (64mb) has no official download for windows 7 but lower.
I am currently upgrading to sp1 with generic vga driver integrated graphics (low res ugh) then i will try find a chipset gpu driver .... does windows update still have drivers for seven?
it has the 3.06ghz P4 socket 478 Prescott
nice sata disk 1tb
It has misbehaved with 4 gpu's so far i limited agp to 4x mode and tried 2 x nvidias and 2x ati's they all crashed.
The memory modules crashed the integrated gpu so i swapped to ddr400 modules (brand new) to install sp1
In ddr2 it only supports 533mhz so 100mhz isn't much of a deal except single data rate will be needing to get some ddr2 533 later I am all out of that snail speed.
I have got official gpu driver to try out the ati that came with this tower again but if it freezes its in the bin.
Hopefully one of the others will work proper (experience index shouldn't crash)
If this effort fails I shall abort and move to xp but i hear prescott not so good on 32bit? I suppose I shall find out as last resort missed out on vista didn't need it with xp at all. 64bit well the multimedia part of that is mostly 32bit.
stupid gpu i have etch a scetch graphics because of you and i may have to settle for xp just to run you.
As an update its been installing 2gb patches today and just about to test the gpu's again.
Hopefully the updates, latest drivers and replaced system ram will encourage normal operation or its recycle time and although i have a sis 315 coming for another pc it'll have to do for this because I'm not loading xp after an all day update just for the chipset gpu 😀
