Reply 21000 of 30771, by pan069
Kahenraz wrote on 2022-02-23, 15:27:
Belts come in all different sizes. There are also square and round belts. I think the best solution is to buy a kit of all different sizes and then try to find one that fits.
Agree, probably best to buy a kit, you can find them on eBay, search for something like this "20PCS Assorted Common Rubber Belt".
The problem with buying a single size belt is that from drive to drive they use different size as well, so having a mixed assortment is actually quite handy. The problem with buying a mix bag of belts is that you end up with a bunch of belts you never use because you only end up using belts in a certain range.
Reply 21001 of 30771, by debs3759
Round is so much more comfortable. Square sounds unnatural.
Reply 21002 of 30771, by pan069
debs3759 wrote on 2022-02-23, 20:33:
I guess it depends. If the wheel surface is flat (as opposed to curved) you want to use a square/flat belt because it will provide more grip.
PS/Edit: Most rubber bands you use day to day are usually square.
Reply 21003 of 30771, by debs3759
pan069 wrote on 2022-02-23, 21:02:
🤣. I guess my humour doesn't always work in text form. I was thinking of spongebob 😀
Reply 21004 of 30771, by Joseph_Joestar
I made a SPDIF Out bracket for my AWE64 Gold.
Wasn't hard at all, and it seems to be working fine.
Reply 21005 of 30771, by pan069
debs3759 wrote on 2022-02-23, 21:06:
Ah, okay. 🤣. Yes, you have to work on that humor-text-format thing 😀
Reply 21006 of 30771, by BitWrangler
90% of them are too stretchy, before you get ideas... However, if you buy one of those giant bags of assorted bands from the dollar/pound or other discount store, you might find a dozen or two that would work as drivebelts... if they happen to be the right size for the thing you're trying to drive. Also found in those and around stalks of broccoli etc at the supermarket are some broad 1cm-ish wide bands that aren't so stretchy, possibly slicing those with razorblade into the width you need might work for some things. One thing with repurposed bands though is you have to eyeball them for thick and thin spots, which make it pull tight and loose as it turns, resulting in uneven speed. Potentially, you might find bags of large O-rings in hardware stores, farm/tool supply type places, which might work where round or square bands are required. Myself, I've had success in the past, when ordering from electronics surplus stores, by throwing in random surplus price belt service kits of whatever they were trying to get rid of for cheap, then mixing and matching. However, those don't come up as much nowadays.
Reply 21007 of 30771, by Shreddoc
Re: belts, it's probably not the cheapest option, but it is one of the rare options out there where you can choose from a range of specific belt sizes, and they ship worldwide : https://fixyouraudio.com/
The attachment belterlouder.png is no longer available
I used them a couple months ago to get replacement belt for my walkman, after seeing them often referenced by searchers for such things, and subsequently found them to be reliable vendors - for what it's worth.
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Reply 21008 of 30771, by Kahenraz
I think the idea is that a round belt is used if the surface is a cup, otherwise you use a flat or square belt. If you put a round belt on a flat surface it will roll off.
Reply 21009 of 30771, by TheAbandonwareGuy
ALERT: Russia has just invaded Ukraine.
Anyone think this will affect retro computer parts prices? I know alot of the cheap compared to US stock parts on eBay ship out of there.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 21010 of 30771, by BitWrangler
Poland, Romania, Czechs etc are gonna make bank. Russian stuff might be blocked by embargo, Ukrainian stuff might not get out.
Reply 21011 of 30771, by Shreddoc
Complex to predict, the overall effect.
It might trouble trade with directly affected areas.
While, in other parts of the world, the whole uproar could even make some people value their retro collection less (hard as that is to imagine, for we here at Vogons!) ...in a "welp, if the whole world is ending / degrading into shit, then I don't reeeally need these 15 x K6/2's anymore! reverse-yoink!" -like manner. /highly_speculative_imaginings
Reply 21012 of 30771, by BitWrangler
Also, toilet paper is gonna be out of stock this week 🤣
Reply 21014 of 30771, by Kahenraz
Two weeks of lockdown to flatten the roll.
Reply 21015 of 30771, by Shreddoc
It's all your fault, trees.
Reply 21016 of 30771, by NyLan
Finished the setup of my A20M :
New Battery, old was KO
Full clean-up.
Put some old-new P3 and Window stickers
Replaced Cd player by a new CDRW ( also have a DVD in its pouch )
Replaced the HDD with a 256GB SSD
Setup Windows98SE and functional Ms-Dos 7.1
Installed Acronis True Image 8 to get a recovery partition in case of issue.
The attachment 2022-02-24 10.45.44.jpg is no longer available
The attachment 2022-02-24 10.45.20.jpg is no longer available
The attachment 2022-02-24 10.45.09.jpg is no longer available
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 21017 of 30771, by Meatball
NyLan wrote on 2022-02-24, 17:48:
Finished the setup of my A20M : […]
Full clean-up.
Wow..nice work!
Reply 21018 of 30771, by RaiderOfLostVoodoo
BitWrangler wrote on 2022-02-24, 04:44:
That was the inspiration for my avatar. 🤣
Reply 21019 of 30771, by TrashPanda
Full clean-up.
I've just spent the last three days with a very touchy Win98se installation, first it crashed every time I tried installing new hardware drivers so I did a nuke and pave which fixed the issue, then it decided to not get along with the PCI sound card it had previously been fine with so I swapped the card for an identical one (same settings) and all was well again then it decided to crash at random times quake 3 arena was running with a known good GPU and clean drivers. (tested both cards in another PC and they work fine, no issues or driver problems)
That third time was my final straw with that 98 install and it and the HDD it resided on was removed from the PC and sent to my sin bin.
New HDD and a ME install and its now working perfectly, now I know what you may be thinking .. it was the HDD causing the issues... nope that HDD was repurposed as a XP boot drive and its running perfectly.
I still hate Win98 just as much now as I did back in the day, its a picky whiny little child of an OS that randomly throws tantrums and wont take no for an answer.
