Reply 21720 of 30476, by framebuffer
- Member
TrashPanda wrote on 2022-05-15, 08:12:framebuffer wrote on 2022-05-15, 07:59:Technically I did this the last weekend, anyways I checked pretty much all my non-in-box mainboards for bulged capacitors and did a re-organisation in the storage to make them more easy to identify
Also found few CPUs I forgot in the socket how knows when 😁Find any bulging ones ? Im curious how storage affects "Cap Plague" era boards and if we as collectors can store such boards in a way that either reduces the chances of caps going bad or stops it.
I'm thinking that cool dry storage conditions would help a lot along with discharging the board before storing it.
Most of the mainboards with bulged caps were already checked at the purchase time with a general note in the inventory and from what I can tell what was supposed to fail, already failed years ago
I didn't noticed any board that, while in storage, got worse than I remembered (but since they are many I can't say it with 100% certainty)
If it's of any interest, here is the list of bulged caps and affected mainboard model after the check
1000uF 10v 40mm 7x1000uF 16v 40mm 6x1000uF 6.3v 40mm 24x1500uF 10v 50mm 1x1500uF 6.3v 40mm 10x1800uF 16v 50mm 1x1800uF 6.3v 40mm 5x2200uF 6.3v 50mm 2x3300uF 6.3v 50mm 20x820uF 6.3v 40mm 2x1000uF 10v 50mm 1x
ASUS A8N-EASUS P4S533-EASUS TUSL2-CASUS P4P800-VMASUS A7V400-MX SEASUS A7N8X-E (2x, were new in box, sealed, never used and full of 3300uF 6.3v completely exploded)ASRock K8NF3-VSTACOMPAQ UWAVEOEM AM39LHP MS-7184MSI 845PE Max (MS-6580)MSI MS-6385MSI K8T Neo2 V2.0MSI K9MM-V (MS-7312)MSI K8T Neo 2 (MS-6702 v1)DFI CA61DFI nF4 LANParty SLIGIGABYTE GA-M61P-S3GIGABYTE GA-8IDML
(the list includes also the full-in-box boards, not only the one you see in the photo)
