Reply 220 of 220, by red-ray
red-ray
Offline
- Oldbie
red-ray wrote on 2025-06-20, 10:42:were it my database I would have fixed it and posted a new .TSV file
PARKE wrote on 2025-06-20, 11:34:If it bothers you open the file in notepad and replace [.00] with []
The reply this deserves would probably get me banned from the forum!
I have been trying to help you correct errors in your data, I have zero interest in editing a file when you fail to post the corrected version.
I assume you also feel I should edit the 2660 to 2666 rather than you fix your data and post the corrected file. SIV does not use/check this field, I wonder how many others are wonky.
Note I also needed to edit L3 Cache into the file.
