What hasn’t been done?
Reply 220 of 238, by Tiido
Unfortunately in context of a Game Gear it won't be usable through the tuner itself, some other device will have to do the equivalent of how the tuner drives the LCD in TV mode. The CVBS signal the tuner ultimately works on is not able to pass enough info for this type of a stunt.
Reply 221 of 238, by Alesia
FPGA or cheaper modern voodoo replacement for era accurate computer builds (IE, not time machines) would be amazing.
Also a replacement battery PCB of some sort for the powerbook 150. I started work on this actually, but I think I lost the gerber files when I moved to linux. (I need to snoop around my computer to see tbh) The main issue was the voltage the PB150 uses for it's battery, a 2.4v rechargable. To make matters worse there is basically no space inside the PB150 for put most battery holders and it got quite over complicated for how inexperienced/unlearned I am in pcb and electronics design. Some kind of PCB+ battery holder that could fit the space and allow for easier battery changes and non-leaky batteries would be very nice.
Reply 222 of 238, by appiah4
a 3dfx Voodoo can be accurately emulated in x86box so I'd guess with a proper bridge interface an FPGA version of it should not be too difficult, possibly even with digital output. Why it does not exist is beyond me..
Reply 223 of 238, by Mamba
OpenPIC super7 motherboard to accomodate dual K6-III+ system.
This would be big.
Reply 224 of 238, by Dothan Burger
appiah4 wrote on 2026-07-27, 10:41:
New Mister cores are dropping every single day with accusations that some are written by Ai. I'm just as surprised Voodoo hasn't been replicated.
Reply 225 of 238, by Jo22
An silly idea: A functional clone of the first Connectix QuickCam (PC version, Centronics).
Maybe by using a Raspbery Pi and its official camera module.
Purpose: To be able to use it for vintage internet software.
It's the only camera supported by GEOS, for example.
Reply 226 of 238, by onethirdxcubed
For making Windows 98 usable on much newer hardware than it was ever designed for, here's the major drivers that are still missing:
- A proper fix for the "Crazy Mouse" bug when using legacy USB mouse support on certain BIOSes. This seems to be caused by vmouse.vxd or msmouse.vxd losing framing when reading from the emulated PS/2 IO port, and can be worked around by using a Windows 3.1 16-bit mouse driver though this still causes other issues like mousewheel and mouse in DOS not to work.
- Support for newer wireless network adapters supporting WPA2. SDZ recently backported a NDIS network driver for Intel gigabit controllers from ReactOS so maybe this is a place to look.
- Better 3d graphics support then is available through VESA and SoftGPU. There are a couple of ways to approach this and JHRobotics seems to be working on one part already by creating a library to allow Mesa to use multiple CPU cores for rendering. It might also be possible to backport a legacy version of Mesa's OpenGL driversto be able to GPU accelerate the rendering on much nerwer hardware though this would be a massive amount of work.
- ACPI power management support on newer machines. This would be very complicated, and there is probably no way to support the IOAPIC or Message Signaled Interrupts because of how the system architecture is.
Reply 227 of 238, by appiah4
Dothan Burger wrote on 2026-07-27, 23:57:
The Raspberry 5 has internal PICe interface which makes mounting it on a PCI card pretty simple in theory as I understand it. From then on it's just emulating the Voodoo in software and interfacing with the PCI bus.. Like.. It sounds like it should be simple and effective. I don't know, but I challenge @polpo to do it 🤣
Reply 228 of 238, by Jo22
^For Windows 3D support, the NEC PowerVR PCX also was a gooid choice, maybe.
Unlike a 3dfx card, it needed no VGA passthrough/loop cable.
The whole communication happened via PCI bus, any 2D could be used.
Even those with proprietary video interface (all in one PCs etc).
I wonder if an FPGA version of such a 3D accelerator would be possible.
No RAMDAC would be involved, making it a purely digital circuit.
Reply 229 of 238, by leileilol
There already had been *TWO* fpga ports of PCem's 3dfx emulation (without attribution) and at least one was definitely vibed, and BOTH didn't use the cards as reference as they didn't even own a Voodoo card and still claimed to be accurate to the hardware. As the FPGA scene has become a hotbed of slop (Like web-facing emscripten ports of anything, FPGA slapdash jobs = clout), it's all monkey's paw wishes at best, pounding sand for the most dishonest jokes of self-proclaimed full stack DevOps to fulfill your Retro Goodness Wish(tm) with you with the help of book-shredding plagiarism chatbots outputting legally toxic bile aberrations of other people's code as their own...
Anyway what hasn't been done is NukedYKT decapping/writing graphics card emulation... one of the few programmers I have faith left in this increasingly slopindundated hobby.
long live PCem
Debian's fucked
Reply 230 of 238, by appiah4
leileilol wrote on 2026-07-29, 23:04:
The FPGA community has gone to genuine shit after AI slop (vibe coding it is now called I thiink? some such bs..) basically wrecked it, but I still hope something good can still be done by someone with actual genuine passion and time.. Call me naive 😁
Reply 231 of 238, by Intel486dx33
PCB rebuild kits.
Retro computers need PCB rebuild kits of your favorite cards
With a NEW PCB and components included in the kits.
Where you can desolder the main components of your cards
And use them on a NEW PCB alongside with new capacitors.
Cards like:
Voodoo
Sound blaster pro
Etc…
Allot of 5he seven cards are starting to go bad
With bad capacitors , traces, brokenness solder joints, etc.
Reply 232 of 238, by BitWrangler
Intel486dx33 wrote on 2026-07-30, 15:06:
PCB rebuild kits. […]
PCB rebuild kits.
Cards like:
Voodoo
Sound blaster pro
Etc…
You can rebuild any motherboard you like as long as it happens to be a PCChips M396F https://github.com/Marco-Both/M396F-Replika/t … ov-file#topview
IDK if there's a couple more models around by now.
Reply 233 of 238, by Living
direct in LED LCD's replacements for CCFL LCD'S.
Reply 234 of 238, by Tiido
That is already a thing, there are a number of LED backlight retrofits for many CFL panels (laptops in particular). But something universal will not happen since there are a bazillion different CFL inverters and interfaces out there and each one must be supported specifically.
Reply 235 of 238, by Living
Tiido wrote on 2026-07-30, 17:06:
not led light, the whole lcd with the 20 or 30 pin connector or an adapter
Reply 236 of 238, by Many Bothans
Are there any Option ROM projects like XTIDE/XUB or extensions to add El Torito bootable optical media functionality to older PC's?
Would be nice for those early to mid-90's MPC systems with CD-ROMs but no innate BIOS support.
  • Zenith Z386SX-20, 8MB FPM, Video 7 1024i, Unhoused
  • AOpen AP43, Am5x86-133@160, 1MB L2, 128MB FPM, Stealth III S540 32MB Savage4, SB32
  • ITX-Llama, 3Dfx V3
  • Asus CUV4X-E, P3-933, 512MB PC133, Hercules 3D Prophet II MX 32MB, SB Live!
Reply 237 of 238, by Tiido
Living wrote on 2026-07-30, 19:07:
There are panels out there with compatible interfaces and mechanical connections (and all out of production from what I know 🤣), but you still are bound to the existing inverter and how it works and there is no sensible way to make those work with the LED backlight in whatever the replacement panel is. There are some ways to scale down the output from the inverter but you lose a lot of efficiency that way and the brightness control range will be very limited in addition. People have tired and they have not succeeded... Unfortunately the inverter is not part of the panel but the display/device, so it will never be avoided and device/display specific solutions remain a firm requirement...
Digital side conversion is relatively simple by comparison, although expensive since the data link speeds are actually very high (both on the old and modern interfaces) and relatively expensive FPGAs (100€ range parts) are needed to do the conversion because of that. Maybe chinese have made dedicated conversion chips for modernizing old industrial equipment...
Reply 238 of 238, by rmay635703
Niche for basically just b&w
Early 2k’s you could get full color backlighting including ones that could do a gradient top to bottom.
A few of my devices have b&w LCDs with funky backlighting, even my scanguage of all things.
