Reply 22020 of 53026, by luckybob
- l33t
wrote:wrote:Well, somebody posted a boxed (new old stock supposedly) Intel VS440FX Pentium Pro motherboard for $12.50 shipped so I bought it. Now I just need a Pentium Pro CPU.
This board was only tested with the 256k L2 cache CPUs. Anybody know if the 512k or 1MB L2 cache CPUs will work with this board?Nick pick. I tried 200/1M in lot of all types boards and working fine. Some older boards showing 0 MB cache in bios/post but in operating system CPU-Z showed 1M.
Problem is with support PII Overdrive 333, but my tip is that thiese Intel boards can run it.
Early chipsets won't be able to use the 1mb cache. I have several motherboards, same brand, same manufacturer, But two different revisions. The earlier board would not even post with 1mb chips, where an almost identical board with a later revision works just fine.
