Reply 22640 of 30758, by kingcake
Today I'm working on an 8088 board with some burned up Tantalums. (Took these with my Microscope)
The attachment FcalENxWQAE566T.jpg is no longer available
The attachment FcakxPZXgAA7SpI.jpg is no longer available
Reply 22641 of 30758, by bjwil1991
Wowsers.
I cleaned the corrosion off of my BioStar 1333/40 386 board since the batteries leaked and luckily, everything else in intact and looks better than before, but not 100% all the way yet.
Reply 22642 of 30758, by kingcake
Can I replace those tag tantalums with modern electrolytics or should I stick with tantalums?
Reply 22643 of 30758, by Horun
kingcake wrote on 2022-09-12, 02:55:
I would replace with equal Tants but you could go with Electrolytics if you already have them but if you have to order them with stick with identical replacements.
And replace them all, if one or two go pop then the rest will follow....just my opinion
Reply 22644 of 30758, by bjwil1991
I read the BIOS from the BioStar 1333/40PME-CH board in case I need to make a new ROM in the future.
Reply 22645 of 30758, by holdencars11
I tested this trash picked 8088 XT Turbo. I was surprised it was a NEC V20... Probably a Juko ST motherboard. Worked first time! Installed Trident TVGA, XT IDE and Vibra 16. Very happy with it being such a painless resurrection!
Ryzen5 1600AF/ASRock B450Mac/16Gb/HD7750
i7 2600K/P67A-C43/16GB/GTX560
i7 960/MSI X58 Pro/8GB/8800GTS
Athlon II x4 620/GA-M56-S3/8GB/8800GTS
Duron 1300/A7S333/512MB/MX440
6x86MX PR200/PC Chips M571/64MB/ET6000
NEC PowerMate1 268 10MHz
And another 40 rigs.
Reply 22646 of 30758, by bjwil1991
I got the BioStar 1333/40PME-CH cleaned up from the battery corrosion and it lives, plus the 33MHz segment display is working after I soldered a wire to the two solder joints that a trace would connect to that had gone bad.
The PCS desktop is finally repaired and working. Next stop: EIDE controller with a sound card and the Kalok drive will get archived to an IDE HDD.
Reply 22647 of 30758, by Veeb0rg
Decided to start getting my HP 9000 and Sun SparcStation 5's up and running and start looking to acquiring an SGI setup hopefully in time to apply to be a exhibitor at VCF East in 2023.
Reply 22648 of 30758, by Bancho
Started to do some more recordings of the Pianobox USB GM Module. Recording Rise Of The Triad sound track which I plan to upload to Youtube at some point.
Here's one of the tracks recorded.
Reply 22649 of 30758, by Nexxen
Tested a Zip 100 drive.
Halfway copying files it would crash W98/2K/Xp and crash the drive on W7/10.
Tested with TIP (trouble in paradise utility that tests the disks) and it would start displaying "error seeking head", probably meaning the head is busted on one side.
Disks retested in another drive were actually good and had very few issues.
Seller sold it as "tested", when actually it was just connected and a disk inserted.
Lately I had very bad luck with Zip drives, only two did actually work 100%, one Jaz is good.
REV I skipped one opportunity as the unit had visible dirt inside (come on!).
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 22650 of 30758, by Veeb0rg
Nexxen wrote on 2022-09-12, 20:49:
Tested a Zip 100 drive. Halfway copying files it would crash W98/2K/Xp and crash the drive on W7/10. […]
was it an internal or one of the externals?
Reply 22651 of 30758, by Nexxen
Veeb0rg wrote on 2022-09-12, 22:53:
USB, looks like a normal floppy in a cheap plastic case.
If you mean the REV, a pic with open lid. I heard a voice "hmmm lemon pledge".
Reply 22652 of 30758, by Romain
Today, quirky but replace my old washing machine by a new.
And my only criterion of selection was finally the LED display that reminds me of my childhood (black + orange) ;p
I'm so happy in 2022 to see this kind of display model, I knew it was the one!
I know you understand me 🤣
Reply 22653 of 30758, by kingcake
Romain wrote on 2022-09-12, 23:30:
Today, quirky but replace my old washing machine by a new. And my only criterion of selection was finally the LED display that r […]
Very cool. Definite mainframe vibes.
Reply 22654 of 30758, by Cosmic
I did my first FSB overclock on my Soyo SY-6BB system today. I picked up a Celeron 366 (SL36C) with plans to overclock from 5.5x66 = 366 MHz to 5.5x100 = 550MHz. This was apparently a very popular and easy to obtain overclock back in the day. However, mine topped out at 83 MHz FSB. 🙁 Seems fine in the BIOS and Plop at 100 MHz, but Windows hangs or complains of missing DLLs. Oh well, maybe a different adapter or stepping would work better. In the end, it was a fun $10 project.
Some photos:
CPU-Z Scores
UMC UM8498: DX2-66 SX955 WB | 32MB FPM | GD5426 VLB | Win3.1/95
MVP3: 600MHz K6-III+ | 256MB SDRAM | MX440 AGP | 98SE/NT4
440BX: 1300MHz P!!!-S SL5XL | 384MB ECC Reg | Quadro FX500 AGP | XP SP3
Reply 22655 of 30758, by smtkr
I wonder how common it was back in the day to get 550 on that. I would have guessed it's the exact same core as a 300A that they just sold at a different price point, so 450 without jacking up the voltage and maybe higher if you cook it a little.
Reply 22656 of 30758, by Romain
Yup, if possible with your motherboard, adjust the voltage to 2.1/2.3v to have a stable front side bus 100 Mhz frequency with this cheap lovely CPU.
Below 2.1v, it's not stable.
Reply 22657 of 30758, by bjwil1991
I fixed up the Aztech Sound Galaxy NX Pro non-16 that had 2 broken off mounting screws for the gamepad/joystick and replaced them with the ones from a dead video card. I also re-bent the bracket to make it more straight and not crooked.
Reply 22658 of 30758, by Cosmic
Romain wrote on 2022-09-13, 06:50:
Good advice, thanks! I just checked and it's pulling 2.03v in the BIOS, that's probably the issue. Unfortunately no way to adjust voltage in the BIOS or on this slotket, but I'm on the lookout for another slotket anyways, so I'll give it a try when I have one that I can configure Vcore on. :)
Reply 22659 of 30758, by Dorunkāku
I made a stepless speed controller for my 486.
From 16MHz to 133Mhz just by turning a knob.
