Munt development ?
Reply 23 of 53, by KingGuppy
Here's a terrible camera photo of my setup for that rip:
http://www.kingguppy.com/files/MT-32-DAQ.jpg
I'm using the µChameleon to capture the digital data:
http://www.starting-point-systems.com/
There are some limitations:
  • The firmware for doing this sort of streaming is still in beta.
  • The streaming mode is very sensitive to the USB interface used. I only got it working reliably on one PC, and then only with a buffering USB hub attached (which I bought for the purpose on SPS's recommendation). They're working on this, but it's not certain that the problem will be solved.
  • I can only capture 16 bits of data at a time, triggered by a separate line (rising edge, falling edge or - in this case - both). There are 2 more lines going to the demuxer that would be nice to capture since they indicate which time slot is being output at any time. However, in most cases it's easy to determine this from the data going to the DAC.
Positives:
  • I didn't find anything cheaper to get the job done without requiring more electronics skills or time than I had.
  • Starting Point Systems' email support is truly excellent.
I've now switched to capturing from my CM-32L instead of the MT-32, giving a full 16-bit resolution.
Thanks to Lord Nightmare for advice and keeping me motivated.
Reply 24 of 53, by NewRisingSun
Actually, the early MT-32 has 16 bits as well; it's just that the 14th bit is not connected to the DAC, and the lower bits are shifted to the left to fill up the hole. The original 16 bits can be found on those pads to the left of the LA32 chip, right below that "M|1" print.
Not that this will improve the sound quality or anything, just something to keep in mind when using this to find out what the LA32 is doing.
By the way, could you post just one more example? I'm referring specifically to the music in Fate of Atlantis that plays either (a) when Sophia tells your fortune, (b) during the Séance, (c) when riding the crab raft. That tune sounds so noisy/grainy on all modules, I would like to hear how it sounds with the digital capture method. Only if it's not too work though. 😀
I have attached the mixdown for everyone's convenience. Hope I mixed it right 😉
    MI2.ogg
    703.12 KiB
    653 downloads
Reply 25 of 53, by KingGuppy
NewRisingSun: I know, but I couldn't actually access the 15th bit (bit 14) easily. I'm using an IC socket wedged on top of the DAC to get at the data lines.
If you give me a MIDI file, and let me know which bit you'd like me to capture, I'd be happy to (preferably no more than ~16s).
Reply 26 of 53, by NewRisingSun
Well, 18 seconds. 😉 (.zipped because this board won't accept .mid extensions.)
It has to be that long because I'd like to see if there's any zero-settling noise. If it's not possible at all, just snap off the final two seconds.
Thank you for your trouble.
    TEST.zip
    301 Bytes
    690 downloads
Reply 27 of 53, by KingGuppy
Sorry about the delay - I'm having transient problems with missing the occasional timer edge transition. This should be OK, though: http://www.kingguppy.com/files/CM32L_NewRisingSun_TEST.zip
The channels are in the following order:
  1. Right reverb dry
  2. Right non-reverb
  3. Nothing
  4. Nothing
  5. Left reverb dry
  6. Left non-reverb
  7. Right reverb wet
  8. Left reverb wet
The rest is as previously described.
I'm not actually sure whether the sample rate is 256kHz (as I originally stated) or 262144Hz (as Lord Nightmare wrote). From my measurements - which are rather inaccurate due to buffering and other issues - it looked like the former.
Reply 31 of 53, by noize
Here I am enjoying Monkey Island 2 on my Nintendo Wii console with the munt mt-32 emulator enabled.
And I am thinking to myself, why this actually sounds good!
It's a little bit off, and there is notably a bit of tweaking to be done.
And yet still so close to sounding like the real thing.
CanadaCow & KingGuppy. What happened?
Reply 32 of 53, by canadacow
What happened?
Life, work, other projects, etc. 😢
If you have an iPhone you can grab my latest creation here: www.zinger-soft.com (I'll even hand out free coupons to forum users!)
Just the same I revisit the MT-32 emulator and the real deal occasionally. You're right. They're sooooo close, but at times, so far. That's kind of the brick wall that at least I ran into. Tweaking the sound to make one instrument work broke another instrument. Eventually my wife wanted to kill me because of all the tuning and note sounds. 'bout drove her (and even myself insane.) I had hoped by now someone else would have picked up the mantle and put new life into my project. Oh well. It'll get completely done one of these days.
Reply 33 of 53, by Kippesoep
Nice one! I just purchased iSSH from the App Store 😁
Reply 36 of 53, by noize
Too bad you stopped working on it.
Can you post the info you find helpfull to continue this project, so someone who for example would participate at Summer of Code, or anyone else for that matter, could easily pick up where you left?
Reply 37 of 53, by KingGuppy
Quick update on this: The project is very much alive.
Mok (who posted some interesting tidbits on this forum a while ago) has provided a powerful shot in the arm to the project. He's been providing us with an endless stream of insights into the MT-32's inner workings - I'm having a lot of trouble keeping up with him. The results should be available in the near future.
Canadacow made an announcement here: http://queststudios.com/smf/index.php/topic,2873.0.html
Reply 38 of 53, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
^now that's good news! 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 39 of 53, by AcidBee
Exciting! Will linux users be able to build this and the alsa driver module with something other than gcc3.3? (I hope, I hope ) 😁
Reply 40 of 53, by KingGuppy
Exciting! Will linux users be able to build this and the alsa driver module with something other than gcc3.3? (I hope, I hope ) Very Happy
I certainly hope so. Linux is my primary development platform right now. I haven't compiled the ALSA driver recently (I've mostly been using the new mt32emu_smf2wav for testing), but I'll try to make sure it compiles and works properly before the next release.
If you know of any specific compilation problems with current CVS HEAD and newer gcc versions, do please let me know.
Reply 41 of 53, by Kippesoep
I'm not sure if it's relevant here, but maybe you want to check out Canadacow's MT32 driver doesn't install on Vista32 for mt32emu driver installation problems with Vista (and the solution).
My site: Ramblings on mostly tech stuff.
