Reply 2340 of 3313, by BEEN_Nath_58
BEEN_Nath_58 wrote on 2025-01-27, 06:30:
BEEN_Nath_58 wrote on 2025-01-27, 06:19:
Team Apache works for me:
Spoke too soon. Game is unstable now, sometimes works sometimes doesn't, just like I76.
I got a hard freeze on computer this time, prompting a hard reset
3rd hard reset as of now...I feel the problem is with some proxying/hooking of RReady with Windows. DDrawCompat had such an issue in 23H2 as well. Similarly DxWnd setting Emulate Win9x heap isn't hookable on Windows 11 24H2 but works on older ones
Reply 2341 of 3313, by sharangad
This is a Win11 24 H2 problem of some sort.
https://patreon.com/Rready
Reply 2342 of 3313, by BEEN_Nath_58
sharangad wrote on 2025-01-27, 07:14:
Not something that I assume to be fixed, I reported some issues back in 2022 in feedback hub, always got back with insufficient information...
Reply 2343 of 3313, by sharangad
BEEN_Nath_58 wrote on 2025-01-27, 07:44:
It might actually be virtualization related. I think I have VM support turned on. I should be able to test it in an hour's time, [EDIT]"Vritual Machine.Platform."
[EDIT2] Nope did nothing, still locks up.
Reply 2344 of 3313, by Grafix
Just an update on joysticks in ICR2 from me!
Both staging and normal dosbox now recognise my wheel and pedals - or my xbox controller. Via the remapper the game now works with either!
BUT
The steering has an obvious centre deadzone. I fixed this in staging dosbox by adding these lines to the joystick section of the staging .conf file
Deadzone = 0
joy1deadzone1 = 0.00
joy1deadzone2 = 0.00
joy2deadzone1 = 0.00
However adding these same lines to the std dosbox does nothing and the deadzone remains - this makes playing with a wheel very unsatisfying unfortunately.
I'm just using staging to bypass this for now but wanted to point it out for future tuning?
Best wishes.
Reply 2345 of 3313, by supererwin
Here's my latest logfiles from the last release.
BTW: CPU load is still quite high... 😀
All the best,
supererwin
Reply 2346 of 3313, by sharangad
Grafix wrote on 2025-01-27, 19:03:
Just an update on joysticks in ICR2 from me! […]
BUT
Deadzone = 0
Best wishes.
Thanks, I'll fix it. Was the problem there before the update?
Reply 2347 of 3313, by sharangad
supererwin wrote on 2025-01-27, 20:13:
Here's my latest logfiles from the last release. […]
All the best,
supererwin
I'm aiming to fix the cpu load issue and the dma stability fix for the next release. Also the deadzone problem.
Reply 2348 of 3313, by sharangad
BUT
Deadzone = 0
Best wishes.
Does it work in Dosbox-Rendition if you add:
[joystick]
circularinput = true
Reply 2349 of 3313, by sharangad
BUT
Deadzone = 0
Best wishes.
Could you share your dosbox-rendition.conf and dosbox-staging-rendition.conf files?
These 3 settings
don't exist and shouldn't do anything. [EDIT] But I can add support for this.[/EDIT]
This:
Deadzone = 0
should work in both builds of Dosbox. But I'll be testing this later today.
Reply 2350 of 3313, by sharangad
ICR2 runningon HD2000 (with a test build of RReady):
https://youtu.be/tb-LC_wqX7M
The work is incomplete and the build isn't entirely stable, but hopefully I can fix that over next few weeks.
Reply 2351 of 3313, by Grafix
sharangad wrote on 2025-01-27, 22:56:
BUT
Deadzone = 0
Best wishes.
Yes it was - I could only use staging at that point but it was there and I'd ignored it thinking there would be a calibration fix in-game or something.
I forgot to say I also added these lines to the .map file generated by the mapper :
joy1deadzone0- = 0.00
joy1deadzone0+ = 0.00
joy1deadzone1- = 0.00
joy1deadzone1+ = 0.00
joy1deadzone2- = 0.00
joy1deadzone2+ = 0.00
joy1deadzone3- = 0.00
joy1deadzone3+ = 0.00
joy1deadzone4- = 0.00
joy1deadzone4+ = 0.00
joy1deadzone5- = 0.00
joy1deadzone5+ = 0.00
joy1deadzone6- = 0.00
joy1deadzone6+ = 0.00
joy1deadzone7- = 0.00
joy1deadzone7+ = 0.00
joy2deadzone0- = 0.00
joy2deadzone0+ = 0.00
joy2deadzone1- = 0.00
joy2deadzone1+ = 0.00
joy2deadzone2- = 0.00
joy2deadzone2+ = 0.00
joy2deadzone3- = 0.00
joy2deadzone3+ = 0.00
joy2deadzone4- = 0.00
joy2deadzone4+ = 0.00
joy2deadzone5- = 0.00
joy2deadzone5+ = 0.00
joy2deadzone6- = 0.00
joy2deadzone6+ = 0.00
joy2deadzone7- = 0.00
joy2deadzone7+ = 0.00
I took both sets of extra code from this thread on Icr2.net where the control deadzone was mentioned in conjunction with using dosbox-x :
https://www.icr2.net/forum/showthread.php?tid … adzone#pid14317
Cheers!
Reply 2352 of 3313, by Grafix
sharangad wrote on 2025-01-27, 23:42:
Could you share your dosbox-rendition.conf and dosbox-staging-rendition.conf files? […]
BUT
Deadzone = 0
Best wishes.
These 3 settings
This:
Deadzone = 0
(I had set that single deadzone= 0 to both conf files but unfortunately it hadn't worked)
Reply 2353 of 3313, by sharangad
Grafix wrote on 2025-01-28, 06:08:
Yes it was - I could only use staging at that point but it was there and I'd ignored it thinking there would be a calibration fi […]
BUT
Deadzone = 0
Best wishes.
Cheers!
OK this is in the mapper. I'll fix the deadzone, not entirely sure why, it's not working. The deadzone only applies to stick 0, I think.
Reply 2354 of 3313, by Grafix
sharangad wrote on 2025-01-28, 07:25:
Cheers!
Brilliant - thank you!
I have tried circular input = true and false btw - neither affected the deadzone issue.
For completeness here are my .conf files too.
Reply 2355 of 3313, by sharangad
@Grafix, could you try this build:
https://nirvtek.com/downloads/RReady.Alpha.20250128.007.7z
MD5: b1ecb96f26a43743b24b57b5f11127db
It adds two new settings:
(for the second stick)
[joystick]
deadzone2 = 10
circularinput2 = false
I have tested stick 1 and also played around with swap34. Setting deadzone=0 does appear to work for me with a gamepad and the left stick.
This build has a lot of changes internally and I can't vouch for its stability. The broken support for Intel HD graphics is in here, it doesn't work too well at the moment.
Reply 2356 of 3313, by Grafix
sharangad wrote on 2025-01-28, 11:19:
@Grafix, could you try this build: https://nirvtek.com/downloads/RReady.Alpha.20250128.007.7z MD5: b1ecb96f26a43743b24b57b5f111 […]
[joystick]
deadzone2 = 10
Bingo...
This worked perfectly for me with both deadzones set to zero - my wheel calibrated in-game without any centre deadspot - awesome!
Thank you!
Reply 2357 of 3313, by BEEN_Nath_58
Why is there an asterisk in game names in the Store?
Did you mean HD 4000 instead of HD400 in the store requirements?
Reply 2358 of 3313, by sharangad
BEEN_Nath_58 wrote on 2025-01-29, 06:02:
Yup, sorry missed that. I'm not allowed to use the game names on the store page or in any marketing material because even that's copyrighted. At least that's what Bethesda told me when I asked for permission.
Reply 2359 of 3313, by robertmo3
sharangad wrote on 2025-01-29, 10:16:
At least that's what B* told me when I asked for permission.
you did what?? are you nuts?? i thought i have already explained you that in the past...
