Reply 23440 of 53065, by Zarchos
Yesterday : 2 untested Acorn A4 (laptop, ARM3 at 26 Mhz)
A few days ago :
- an 8080 all-in-one Soviet PC : L'VOV
https://www.youtube.com/watch?v=bHhU_1hXWTE
Львов (L'vov) PK01 - very good condition, full works , manual, original box, power source , cabels
Львов (L'vov) PK01
The L'vov was made by an Ukrainian company called "V. I. Lenin". It is also called "Lviv" is KR580WM80A based with 64k of RAM and 8k of ROM.
Resolution: 256x256, but this is the full size of videoframe, excluding border we will have 220x200 points. No text mode, only graphic. (To access 16kb of graphic RAM You need to switch RAM pages).
Technical Overview:
Year: 1986 CPU: KR580WM80A or KR155
RAM/ROM: 64kB / 8 kB Clone: none
Colors: 4 Resolution: 256x256
- An Olivetti Prodest128 (Rebadged Thomson MO6).
Reply 23441 of 53065, by DaveJustDave
Good that you have two. You should leave instructions that you are to be buried with those two coins on your eyes!
Artex wrote:
Picked up my second one of these little guys. Retro enough I guess! […]
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 23442 of 53065, by Artex
Nicely done! 😀
Reply 23443 of 53065, by tegrady
tegrady wrote:
Won this auction for "Assorted Computer Components Lot". […]
Nowhere in the description did it say what they were actually selling, but I am pretty sure that's an Awe 32 PNP with some sort of add-on module. I'm not really sure what the add-on module is though.
It also includes a unknown Trident ISA VGA card. The third card is a bit of a mystery. There is no IO on it, but it seems to have an IDE or Floppy port on it. Maybe its an IDE or Floppy controller card?
I don't think anyone else really knew what they were selling, so I got a very good deal, assuming they all work.
These cards finally arrived a couple of days ago.
The cards are the Awe32 CT3990, the Wave Blaster II daughter card, a Trident TVGA8900C ISA SVGA card and a Creative CT1870 controller card. I was mainly interested in the Awe32, but the Trident card will come in handy in a 286 or 386 computer somewhere down the road. I probably won't be using the CT1870 though.
I have installed the Awe32 in my latest build and it works perfectly!
This was definitely one of my best finds recently!
    1.07 MiB
Reply 23444 of 53065, by Gered
Been grabbing a bunch of different PS/2 to DB9 Serial adapters one at a time over the past couple months, trying to find one that would work with my Microsoft IntelliMouse that does clearly say "Serial or PS/2 Compatible" on the bottom. Don't actually need to use this mouse with a serial port at the moment, but just wanted to make sure I had what I needed should the need arise.
Anyway, of course as most know, not all of these adapters actually work with PS/2 mice (even if it does say right on the mouse that it's "serial compatible"). I've found that trying to find the correct one was challenging and ended up getting several ones that did not work. Problem is that most of these adapters don't have any labelling on them and they all look fairly similar. Anyway, got two the other day finally that both did work. Figured I'd share what they looked like so anyone else looking for these in the future knows what to look for:
The one on the left actually does say "Microsoft" on it as you can see, which the seller's photo did not show, heh. The one on the right has no labelling other then the little arrow picture. But it also works just as well as the one on the left.
These next two seem to be very common on eBay. They do not work with my Microsoft PS/2 IntelliMouse, so maybe stay clear of them!
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 23445 of 53065, by DaveJustDave
picked up a pair of mint in box Roland MA-12c studio monitors to use with my 486 build
334.59 KiB
Reply 23446 of 53065, by Batyra
Nice!
Reply 23447 of 53065, by chose007
I thought that adapter is for Miro Voodoo2 😁 because must make one for my card
I got same problems like you with non-compatibility ... same with PS/2 - USB adapter, better use COM mouse for COM ports.
and some new stuff in garage
Reply 23448 of 53065, by dionb
Got myself another loot box yesterday 😉
Not too spectacular this time, the centerpiece is that Intel MU440EX board, with Rage Pro and Yamaha YMF940 onboard. Was sort of hoping the CPU was going to be a Celeron 333A (this was the exact config of my work PC back in 2000 - MU440EX, C333A and 64MB RAM), but no, it's a 266MHz Covington. Apart from that some nice little VGA cards, including a Diamond Speedstar A50 (if anyone was ever going to love a SiS-based card they'd love this one) and an STB Nitro 64V (GD5446-based) with socketed EDO chips. Lots of DIMMs, although most with very low capactiy - 4x 16MB, 2x 32MB and that big one is a whopping 64MB. Great for maxing out the cacheable area of an i430VX or Via VPX, not for much else. The upper PSU is interesting, a very, very heavily built Dell 250W affair. Interesting bit is that it actually has a normal ATX pinout.
Encountered one odd one in the pile of cables:
Anyone know what this one is for?
Reply 23449 of 53065, by Turbo ->
Got a Pentium 75mhz socket 7 computer for my collection, and two 15" LCD monitors with a bunch of vga, dvi and power cables.
    384.82 KiB
Reply 23450 of 53065, by JidaiGeki
dionb wrote:
Got myself another loot box yesterday ;) […]
Could it be http://pinoutguide.com/Motherboard/dell_optip … nt_pinout.shtml ? Keyed on pin 21 and goes with the Dell theme 😀
Reply 23451 of 53065, by dionb
Looks very likely given the abundance of other Dell stuff in this load, although that Dell PSU doesn't look like something out of a GX280...
Reply 23452 of 53065, by KCompRoom2000
I believe that pinout was used throughout the entire midnight-grey Dell Optiplex line, so GX50/GX150 all the way up to GX280. Nice score on the power supply, should be a good candidate for anything that calls for a 250W ATX supply. I actually have a newer (P4-era standard) ATX Dell 200W PSU in my Celeron-433 build and it's pretty solid. Of course, be sure to check the capacitors just in case.
Reply 23453 of 53065, by cyclone3d
This ESS488-F (I think) based card with what looks to be an OPL2 clone chip.
266.43 KiB
319.79 KiB
387.33 KiB
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 23454 of 53065, by Nvm1
I got back from a week of holiday and made the first pictures of the 5 boxes full of hardware:
The AT Tower nr1:
1.67 MiB
AT Tower nr1 front
Inside of the AT Tower nr1:
1.73 MiB
Inside AT Tower nr1
The Gigabyte GA486SV VLB Motherboard:
1.75 MiB
Gigabyte GA486SV VLB Mobo
Has very minor battery leakage, that barrel battery will be gone today and I will clean the whole board of any residue.
The S3 805P VLB graphics card with 2MB ram:
1.81 MiB
S3 805P VLB 2MB
And as soundcard the Creative CT3670 with Ram:
1.99 MiB
Creative CT3670
To be continued!
Reply 23455 of 53065, by Nvm1
Also inside the AT Tower nr1:
Buslogic SCSI Controller VLB:
1.9 MiB
Buslogic VLB Scsi controller
Seagate Medalist 3210:
1.14 MiB
Seagate 3.5" Medalist 3210
Voodoo 5500 Box!
1.5 MiB
Voodoo 5500 Box
The 5500 and driver disc itself:
1.69 MiB
Voodoo 5500 AGP
And an Asus P4P800-E Deluxe including box + 4GB Ram + all extra's!
1.93 MiB
Asus P4P800-E Deluxe incl all
I still need to take pictures of all the rest but after unpacking this I ran shortly out of space 🤣
We still need to unpack from our holiday so after the first machines of dirty clothes are gone I will continue.. 😉
Reply 23456 of 53065, by CarlHopkinsUK
Nipped out for lunch, ran past the local charity shop and grabbed these - £2.80
367.63 KiB
Nothing spectacular but £2.50 for a joystick for the skt370 build, yes il take that!
Reply 23457 of 53065, by Batyra
Haven't seen it anywhere for a while. Just bought Synergy Viper MAX - complete in box.
(sellers photo)
237.52 KiB
SynergyViperMax
Reply 23458 of 53065, by rikukos
What better way to celebrate my 50th post here on Vogons than a good old boxed Roland? Uhh...two boxed Roland!!? Well, either way I'm not the man spitting on a relatively rare NIB/NOS item offered at a below "going rate" (from the Amibay..). Passing one of these to a fellow (retro) enthusiast leaving me one, though. That said, already had one of these SCM-10AT boxed babies along with their big brother, the mighty SCM-15AT, so she is definitely not going to feel her alone!! Not caring much about about wavetables inside but piling up some boxed Roland "intelligent mode" cards in one's inventory can only mean a good thing..
This then..a bit too "modern" for my liking but decided to catch this Terratec Mystify 4600 (Ti4600) regardless. I don't see (sealed) GeForce4 Ti4600 cards too often so nice to add one to my collection. Plus that it should make a decent Windows 98 card if I ever get interested in those Windows era games again, I believe.
My fav GUS card - congrats!
Reply 23459 of 53065, by bjwil1991
Lucky. That's amazing to see those Roland cards.
